Pacbrake PRXB
Old Jun 21, 2009 | 12:28 PM
wazz_zup's Avatar
Pacbrake PRXB
I'd love to install one of these on my rig. I'm now hesitating because of this 2010 Ca smog check requirement bs. see below:
http://www.dca.ca.gov/publications/p...0305_dca.shtml
Am I going to have to pull this off when it's time to smog? Will there be any traces left behind at the OBDII?
Old Jun 21, 2009 | 08:26 PM
wiskeyVI's Avatar
What would this change???
It's just a butterfly valve in the system.
BUT....Mine jst quit for the second time.....
Old Jun 21, 2009 | 09:29 PM
TonyB's Avatar
Exhaust brakes are offered as a dealer installed option...does NOT affect emissions.
Tony
Old Jun 22, 2009 | 11:29 AM
CTD NUT's Avatar
I read the link.....what did I miss?
An exhaust brake is not an emissions device and will not affect the engines emissions performance or alter the existing emissions controls on your truck. What is the issue/problem?
Old Jun 22, 2009 | 02:02 PM
wazz_zup's Avatar
Looks like a pretty basic install but you are plugging wires into the TIMP system on the 2006 and later models and.......bypassing the ECM??? Maybe I'm just being extra cautious. I hopefully attached the install below. Check it out and let me know if I'm getting excited over nothing.
File Type: pdf
Old Jun 22, 2009 | 04:47 PM
CTD NUT's Avatar
You are getting excited over nothing.
You are not bypasing the ECM UNLESS you buy the ECM bypass kit....and even when bypassed, it simply means the EB is engaged manually. Which, again, has nothing to do with how the ECM runs the engine or any of the emissions compliances your truck meets.
Old Jun 22, 2009 | 05:57 PM
wazz_zup's Avatar
10-4 Thanks CTD...now I just got to come up with the funds!
Old Jun 22, 2009 | 06:44 PM
quadman20's Avatar
Larry's got the best price.
I too was hesitent on installing mine at first. But take your time and do like they say. Since the install is for multi year trucks somethings will be differant then the pics. The only gripe I have is the wire harness for relays should be year specific as a 06 is differant wiring then 05-. So some wires are not long enough and others are way long. I did some slight changes on some things mostly hose routing. If you got a buddy to help it well worth some beer and steaks.
Old Jun 22, 2009 | 07:54 PM
wazz_zup's Avatar
Quadman20, you got the contact info for Larry? (Or Lary, as I've seen) I've seen his name thrown around here on the boards. I'd like to pm him for a price on the C44045.
Interesting that you mention some beer and steaks...got a buddy that mentioned he'd help for a steak dinner and a couple beers!
Old Jun 22, 2009 | 10:39 PM
quadman20's Avatar
Sent you a PM have beer and steaks and I'm there.
Old Jun 22, 2009 | 11:07 PM
RiverRat2's Avatar
Hey I'm In!!!!!!!!!! I'll get My exhaust brake kit and we'll do two of em!!!! LOLOL!!!!
Old Jun 23, 2009 | 12:44 AM
Fisherguy's Avatar
It's a great unit, got mine from Lary as well, install is not a big deal (I did mine) and there's nothing wrong with the wiring harness.
Old Jun 23, 2009 | 10:10 AM
CTD NUT's Avatar
I also got my PRXB from Lary. He had the best price around at the time. Install is remarkably simple. I had zero issues with the wiring on my 03 6spd.
Old Jun 23, 2009 | 12:08 PM
wazz_zup's Avatar
One more question...If you get the standard tank and compressor, can you upgrade to a larger tank/compressor later? Might wanna run in impact gun when hauling the big 5ver around! It's got "China bombs" on there and I'm watch 'em like a hawk when on the road.
Old Jun 23, 2009 | 02:05 PM
wazz_zup's Avatar
Just talked to Lary at the DTR store and got-er-comming.....very nice guy!
Thanks boys for all your help.
