Truck Pulling right, has anyone solved the issue?
Moved the caster cam bolt as much as i could to make it pull to the left....seemed to help but did not solve the issue. Ball joints seem good. Has anyone actually had the issue fixed?? Offset balljoints?
before you make a bunch of adjustments to make it roll straight get it out on a perfectly level parking lot and see if it still pulls to the right.. or drive down the left side (yea wrong way) and see if it pulls left..
Most if not all streets have a crown on them and slope away from the center of the street, we drive on the right so the truck naturally pulls to the right.
Mine pulls to the right on the street but on the freeway it pulls to the left because the freeway drain is in the middle so the freeway slopes to the left.
Correct me if I am wrong but the factory sets up every vehicle to pull to the right so that if the operator falls asleep at the wheel then the car will coast of the highway towards the ditch or field depending on where you are located instead of into on coming traffic causing a serious accident. I noticed after I installed my 35's that my truck pulled more to the right than before and the only thing I can come up with is that with a bigger tire you have more weight and with more weight you have more pull but maybe I have no clue on this subject
I had the same problem after a rotation. Turned out to be a tire pull. Don't do any adjustments to alter from factory settings. Swap the front tires left to right and see if the pull follows. Mine did follow after this. Darn Goodyear tires. I just had my Goodyear SR-A tires warrantied out due to cracking one inch from the bead. Got a set of Goodyear Silent armers on now. Only cost me $650 dollars for 6 new tires. Can't complain.
It seems to me the guys having the pulling problems all have lifts, and/or oversize tires. I think 4x4's will have a little more "pulling" tendencies as well.
Just my .02
MY 03 and my brother's 03 both pulled right without lifts or bigger tires. Yes, they do set them to slowly pull right, but not that much. It is a problem with some of the trucks. My 05 steers straight, as does his 06. My son's 03 really started pulling so he took it in, and he had to replace the left ball joints, which is a problem with the trucks as well.
2) the rear axle is not square to the frame of the vehicle. There is a thrust angle causing the vehicle to not go straight. This condition, while sometimes visible by comparing wheelbase from one side to the other (using a tape measure) is most easily measured with an alignment machine. It can be corrected by loosening the rear axle's U-bolts and centering the axle housing.
I rotate my tires every 5K and it is slowly getting worse....I noticed it about 30K and now it has 60K....I did notice the inside of the drivers side front tire is wore a little more than the outside.
Mine tracked straight with the stock tires and still tracks straight with the KORE Leveling and 35" tires. Recently I noticed a slight pull to the right, checked the tire pressure on the right front and it was lower by just a few pounds. Aired it up, back to tracking straight. When I get on roads with a visually noticable crown to the right for drainage, it also pulls a little right, but it's the road not the truck. Same applies to a left crowned road. The crown in the road does wear down your tires, rotations are extremely important in managing the wear down and keeping you traveling straight.
CD
CD
Good advice here. Is this truck a 4WD? If so, you CAN'T adjust caster on one side relative to the other. You can't actually twist the solid axle, and all you'll succeed in doing is causing the front axle to be out-of-square with the frame. The two most common causes of a steering pull on our trucks is: 1) as was mentioned, a tire pull. Try cross switching the front tires.
Left 4.7 and Right 4.5. This is the same as the last two alignments that i have had and match the origianl factory setting. Does this mean that my axle is not square to the frame ? Should I have the shop adjust both to same measurement ?
