Truck died on freeway
Truck has performed perfectly for 19,000 miles until last Friday. I was on the freeway in stop-and-go traffic when I noticed some hesitation and stumbling. It got worse, then the truck just died. I pulled over, waited a moment, then restarted. After a long crank it fired right up and drove fine.
I changed the fuel filter after that (it had about 7,000 miles on it) and also checked the airbox and intercooler hoses just to make sure nothing was wrong with those. Everything checked out fine.
This afternoon, I did a full-throttle run to 60 MPH and the truck stumbled in the 2500 RPM range.
Any ideas on what may be happening? There are no codes.
I thought the CP3 could pull through a dead lift pump. The in-tank ones are flow-through, yea?
Rampage1967
Jan 31, 2008 05:00 PM
