Transfer Case Help
Old Jan 24, 2008 | 08:11 PM
mjsandt's Avatar
Transfer Case Help
I was wondering if anyone could help me out with the extact specs for my transfer case. I have been looking around, and I beleive in 2004 they reduced the number of splines on the output/input shaft from 29 to 23, but I dont know. I need a new t-case, and have been looking for one, and trying to figure out how many splines I have, and which T case will wokr. I know it is the NV271D, but there are different part numbers for the 271 based on output/input shafts. Thanks guys.
M Sandt
Old Jan 24, 2008 | 09:20 PM
04crewcablong's Avatar
will let you know tomorrow gotta check the books at work
Old Jan 24, 2008 | 09:53 PM
06trx's Avatar
The D in 271D states the it is for a Dodge. We make a couple different 271 cases. I am at work now and will go out to an assm. line and check for you. Jeff
Old Jan 24, 2008 | 09:57 PM
06trx's Avatar
By the way is this for an 03 or 04? What happend to your case?
Old Jan 25, 2008 | 03:37 AM
msurf's Avatar
Yes what happened? I am wondering about mine...it may be whining and it sure has a lot of radial slop...about 2 inches. I believe this is where my clunking is coming from. Any insight?
Old Jan 25, 2008 | 04:58 PM
mjsandt's Avatar
Im not sure, there is definately somethign wrong with it. In 2x4 it is fine, but when 4x4 is engaged, it makes a horrible clunking/grinding noise when it is under a load. If you are rolling and idling, it is fine, but if you give it some throttle or turn the wheels, it grinds and makes noise. I was wondering because I found a good deal on a case, but am making sure it will fit. The cause was from loss of fluid, and I didnt catch it in time. I saw wome ATF on the undercab, but checked my tranny fluid and it was fine, I didnt know at the time that the t case takes ATF. I might get it rebuilt, but if this case will fit, it will be cheaper, and I wont be without my truck very long if I do a swap.
It is for an 03 2500, with a 48RE, if it makes a differance. Thanks.
M Sandt
wyododge
Aug 18, 2011 07:48 AM
99-2500
Aug 3, 2006 02:13 PM
Rome
Apr 19, 2003 06:09 PM
Nicholas
Dec 24, 2002 06:02 AM
