Transfer case fluid change, help... pic included
Hi everyone, I am wanting to get my transfer case fluid changed out and am wanting a little help. I have not done this before but i know apparently its very simple. my question is, in the pic below, do I unscrew #2 (drain plug???) and let it all drain out and then unscrew & refill in the #1 plug (refill plug???). Is it that easy? I believe you use just over 2 quarts? I already have some mopar atf+4 ready to be used. Thanks everyone in advance...
Thanks,
Eric
Thanks,
Eric
Thanks for all the help guys. Today was pretty good, got my fuel filter done, engine, rear end and transfer case. Transfer case was way easy. Thanks again!
good point HL649 lol that would suck!
One note the rear end. Later trucks have an oil level line stamped into the cover. You could miss it if you didn't know it was there. Fill line is a fair bit below the bottom of the plug.
On the rear, just fill it till it starts to run out. Despite what some people have posted, it will cause no harm. I have over 40k on my rear will no issues.
Good advice on pulling the fill plug first on the t-case.
The manuals state to fill the rear to 1/4" below the hole, plus or minus 1/4". So, in reality, it's a wash. Anything from 1/2" below the hole to filling until it runs out is A-OK and within spec.
Good topic! My tcase is next. What size allen is needed?
I did the rear diff on Sunday. I used 3.8L of Mobil 1. The reusable gasket makes the job super easy.
