Transfer Case
Old Jan 2, 2011 | 04:53 PM
jsabeh's Avatar
Transfer Case
I drove cross country to NJ from San Diego. When I got there I had new batteries put in, new seals on the differentials, oil change and Transmission fluid change. I asked to have the transfer case drained and refilled but the service manager said the fluid was pristine and there was no reason to change it. When I returned home the San Diego Dodge dealer said the fluid had to be changed because of time/miles even though I had not used 4 wheel drive more than a few times. Who is right, I don't believe that the fluid goes bad because of time or miles (not put on it.)
Old Jan 2, 2011 | 05:13 PM
rockcrawler304's Avatar
You are using the transfercase every time you drive. Things are spinning and friction is causing the fluid to break down. How many miles are on the truck? I don't have the owners manual by me but IIRC the fluid is recommended to be changed at 50k miles. If you are at or over that I would change it.
Old Jan 2, 2011 | 05:14 PM
wyoburner's Avatar
I would change it. Your only looking at about 20 dollars worth of oil and 1/2 labor at the most. The transfer case turns all the time wether or not it is in four wheel drive
wyododge
Aug 18, 2011 07:48 AM
csramsey640
Jul 6, 2006 04:44 PM
8mpg
May 22, 2006 01:35 PM
hw101
Mar 16, 2003 12:07 PM
