trans too hot
Old Jun 29, 2012 | 08:10 PM
jbreavis54's Avatar
trans too hot
Hey guys, i had posted earlier about my trans running too hot! I have an 05 3500 48re. Running around (about 55), my trans temp is around 190 to 200. I stopped and put it in neutral and within 5 minutes it was up to 210. The outside temp was around 92 while i was driving. I just finished replacing the trans cooler and removing the check ball. Unfortunately the problem is still there. Pulling a 9000 lb camper, temps reach 250 and higher. Any ideas on what my next step should be?
Old Jul 2, 2012 | 08:37 PM
jbreavis54's Avatar
problem solved!
Turns out the new trans cooler had a place for the thermostat, but no thermostat. Fluid was constantly being bypassed and not cooled. I closed off the bypass and so far, problem seems to be solved! Thanks for all of your replies!
Old Jul 2, 2012 | 09:38 PM
CoastalDav's Avatar
Glad you found the problem. Mine runs 100 degrees above ambient outside temp. Will get hotter stop light to stop light. Towing is about the same. 95+ I have to slow down to keep it under 200 when towing. Normal tow speed is about 62-63 mph.
What cooler did you install? and how much cooler is it running.
Dave
Old Jul 2, 2012 | 09:46 PM
jbreavis54's Avatar
Im not sure what brand of cooler it is, i picked it up at an auto parts store for about $180. It's supposed to be a stock replacement so i figured everything was right. But it seems to be fine now that the bypass is shut off.
Old Jul 2, 2012 | 09:49 PM
jbreavis54's Avatar
Now its running between 165 and 175 with no load about, so roughly about 25 degrees cooler.
Old Jul 3, 2012 | 10:20 AM
Lost Lake's Avatar
So the bypass is thermostatically controlled?????
Old Jul 3, 2012 | 10:34 AM
CoastalDav's Avatar
The tranny air to fluid cooler in the front of the grill does have a thermostat
in the line. Before that opens and allows flow, the tranny fluid is heated up by a liquid to fluid (heater/cooler) that uses engine coolant. So you might say
the engineers want the fluid at least to engine temp.
I have a picture of the system, since I considered removing the thermostat
in the line that leads to the tranny cooler up front.
Dave
Old Jul 3, 2012 | 10:51 AM
jbreavis54's Avatar
Yeah the hot fluid goes into the fluid to fluid cooler first then to the fluid to air cooler up front which has a thermostat on the top drivers side, then back to the tranny.
Old Jul 3, 2012 | 10:56 AM
jbreavis54's Avatar
From what i've read, the thermostat is supposed to help cold climate trucks warm up quicker by bypassing the cooler until it reaches a certain temp. They're also bad about sticking. Definately not needed here in nc!
whosdunit
Feb 16, 2019 04:07 PM
Strjock81
16
Dec 12, 2007 09:53 AM
Sea:\>Drive
Jan 15, 2007 05:26 PM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
