Trans fluid circulation???
Old Jun 27, 2007 | 10:35 AM
BMH95's Avatar
Is there any easy way to make the stock valve body ciculate fluid in park?
Old Jun 27, 2007 | 11:17 AM
TonyB's Avatar
Yes...Call around to local trans shops that understand Dodge Trans'...they should know how/where to mod the valve body for fluid flow.
Tony
Old Jun 27, 2007 | 12:32 PM
Rob C's Avatar
also most aftermarket valve bodies have this mod performed already.
Old Jun 27, 2007 | 01:45 PM
BMH95's Avatar
I know they sell them, but I don't have the free money to buy a converter and valve body right now . . . so I was scheming for a possible DIY mod to simply get the fluid flowing until I can spring for the whole deal.
Old Jun 27, 2007 | 06:09 PM
MotorX's Avatar
Hi guys,
New here and new to diesel. Are you talking the 48RE Trans? If so, I'm assuming what you are saying is that one can be fried if left in park too long with motor running??? What, is it better to leave it in gear on short stops when motor is on? TIA
Old Jun 27, 2007 | 06:12 PM
ptgarcia's Avatar
Originally Posted by MotorX
Hi guys,
I believe it circulates fluid in neutral. Whatever you do, DO NOT leave it in gear while unattended!
Old Jun 28, 2007 | 01:10 AM
no_6_oh_no's Avatar
Hi guys,
The stock 48RE does not circulate fluid in park. Running in park too long starves the pump of fluid and cooling. Put it in neutral and set the parking brake for stops of more than a couple of minutes.
Old Jun 28, 2007 | 01:11 PM
shortbed rv's Avatar
FYI: The trans does not circulate in reverse. If you are backing a heavy load uphill and the trans temp light comes on. Stop and shift to netural and set the brake and wait while the temps cool.
Note: While backing you are not watching your guages ( hopefully you are looking back) just beware that the trans can heat up.
Old Jun 28, 2007 | 01:14 PM
MotorX's Avatar
So, 'park' differs from 'neutral' by more than just the parking paw. Hmmm.... I've heard of that on some trannys. This must be one of em'. lol
Good to know. Thanks guys.
Old Jun 28, 2007 | 04:06 PM
TonyB's Avatar
Actually most if not ALL dodge tranmissions are designed this way.
Tony
Old Jun 28, 2007 | 04:59 PM
no_6_oh_no's Avatar
Tony
Nope, only the ones based on the old Torque Flight design. All the newer car/SUV/light truck autos are computer shifted and circulate in park. The 48RE was the last of the dinos that was not modernized. That ended in Jan 07 along with the 5.9, may it RIP.
Old Jun 28, 2007 | 05:14 PM
bigdav160's Avatar
Some mis-info going on in this thread.
Look at the hydraulic charts. "Park" is the only gear range that doesn't charge the converter or cooler circuit. Fluid always moves through the pump (and is lubricated) if the engine is running.
Just buy a shift kit. The instructions for modification are in the kit. Like this one:
http://dunriteconverters.com/transbuddy.html
Old Jun 29, 2007 | 02:34 AM
TexasCTD's Avatar
It also helps to keep the tranny cooler if you back up in 4 low if you have a 4x4.
Old Jun 29, 2007 | 11:32 AM
no_6_oh_no's Avatar
Then quite spreading the mis-info around.
Look at the charts again, TC 0 pressure, cooler 0 pressure, line pressure 10-20 lbs. Line pressure is a closed loop in park, nothing in nothing out. Unless fluid flows thru the TC and cooler flow is zero.
There is less than a pint of fluid in the VB and pump when manual valve is in park position. The only cooling is that little bit and there is no flow to relace it unless the VB is modified.
Polarlys
Jun 25, 2010 10:11 PM
mppd20
Nov 20, 2008 07:37 AM
triplenickel
Nov 2, 2005 04:28 PM
Crimedog
Oct 20, 2005 11:34 PM
kevellis32
Mar 19, 2005 02:01 PM
