trans fluid
Old Aug 21, 2007 | 10:57 PM
dogcamo's Avatar
trans fluid
Hey folks, looking for some input. What do you all say is a good quality fluid to use. I have 24k on the truck and will be changing fluid at 30k.
Old Aug 22, 2007 | 12:18 AM
Roperteacher's Avatar
AMSOIL ATF ( Rated ATF+4 ) all the way!
Old Aug 22, 2007 | 12:58 AM
TexasCTD's Avatar
The Mopar ATF +4 is good stuff. I buy at the local Dodge Dealer (about the only thing I get there) for about $21 a gallon....with a little bit of negotiation.
Old Aug 22, 2007 | 06:37 AM
kry226's Avatar
For warranty purposes, get Mopar ATF+4 at Walmart for $4.42 / qt. That's just under $18 / gal, then add tax. I love Amsoil stuff and run it in everything else, but the Mopar stuff will be in my tranny until the warranty runs out. I do change mine every 25K though.
Old Aug 22, 2007 | 02:29 PM
coparam4x4's Avatar
Valvoline Syn ATF+4 worked for me. $4.95/qt at autozone. Amsoil when I get my tranny built.
Old Aug 22, 2007 | 06:12 PM
rjm022's Avatar
Valvoline Syn ATF+4 for me too! advanced auto had it on sale earlier this summer for 2.96 a qt!!! or it was marked wrong. either way, i bought two cases!!!
Old Aug 22, 2007 | 06:48 PM
gtstrkd's Avatar
When yall change the tranny fluid is it ok to mix factory with different?
Old Aug 22, 2007 | 10:23 PM
coparam4x4's Avatar
All I did was drop pan, change filter, add 6.5 qts back so mine was mixed with factory fill. So far so good........
Old Aug 23, 2007 | 01:29 PM
DBLR's Avatar
Using Amsoil ATF should not cause any problems with your Dodge warranty. I had my Dodge dealer install 6.5 qts of Amsoil of ATF when they serviced my transmission. The Service Manager even said it would not void my warranty as Amsoil has very good ATF and its better then what Dodge uses.
Old Aug 23, 2007 | 01:59 PM
soulezoo's Avatar
DTR 1st Sergeant
Another Amsoil in the tranny here... Amsoil makes quality products across the board. I say that even though I use Schaffer's everywhere else.
Old Aug 23, 2007 | 08:59 PM
dogcamo's Avatar
Thanks to all for your input
Old Aug 24, 2007 | 07:03 AM
kry226's Avatar
I do not disagree with you. I am simply stating that all dealers are different and if one is running Amsoil in the tranny during a failure, then they have a significantly tougher case to prove than one running ATF+4. Right, wrong, or indifferent, that's just reality.
Old Aug 24, 2007 | 07:53 PM
gtstrkd's Avatar
I went and asked a dodge dealership how much they charged to change the tranny fluid and they said they wont just change it they flush it only and want 175 dollars. Is there any other way to get all the fluid out of the converter too?
Old Aug 24, 2007 | 10:05 PM
There are dodge dealers who actually STOCK and SELL AMSOIL. Carson dodge being one of the very best...
Old Aug 24, 2007 | 10:28 PM
D-Roc's Avatar
I run Redline C+ATF in mine.
archer39
Dec 5, 2009 07:40 PM
mar67655
Mar 14, 2009 07:22 PM
nfsommer
Nov 9, 2007 09:36 AM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
