trans cooling lines?
Old Jan 14, 2006 | 06:00 PM
slowDodge's Avatar
From front to back. the two coolent lines run from the cooler to what? Then they run to the trans. Where the rubber hoses join to the steel ones i have a bad leek, I need to change both hoses. where do they go and it looks like it will be kinda hard to change. Any comments. I guess the more power the more problems yeehaa. where should i get them.
Old Jan 14, 2006 | 07:17 PM
Bad Ramer Jamer's Avatar
Mine go to the transmission cooler. It's located on the side of the engine. I think the cooler also double's as a heat exchanger for the engine, but I'm not sure of that, I just read it somewhere. You will have to get the line's at the dealer.
EDIT:
Sorry, re-read your post. The line's go from the cooler to the radiator.
Old Jan 15, 2006 | 12:19 AM
no_6_oh_no's Avatar
They should run from the trans to the heat exchanger on drivers side of the block then to the trans cooler in front of the radiator. Probably going to be a dealer item unless you can find somebody to build them for you.
stan
Aug 7, 2014 09:43 AM
John Faughn
17
Dec 12, 2005 07:11 PM
MrKen
Feb 25, 2005 04:22 AM
mopar2ya
Apr 1, 2004 06:42 AM
