Tranny slip in cold weather?
Old Mar 5, 2008 | 05:25 PM
TexAg's Avatar
Two mornings ago it was about 30 deg. F. outside and the engine block heater had been plugged in awhile so she was nice and warm, but as I drove out the tranny seemed to be slipping as I accelerated (too high revs and not getting much power). Could the cold weather have anything to do with this? Its never happened before, but I didn't idle her too long either because I had her plugged in. 19K miles on her. I've had her mostly in Performance mode on the Bully Dog (what it was in when it slipped too), but have driven a significant amount in Crazy Larry too because it was getting best mpg. I'm not overly hard on the truck either, only towed a travel trailer once (to NM 6 months ago) and not a lead foot.
Its not happened again, but I am concerned, any thoughts?
Old Mar 5, 2008 | 05:56 PM
billie's Avatar
Do your idle in neutral rather than park. The pump doesn't run in park so neutral will fill the TC etc before you go.
Cya
Old Mar 5, 2008 | 06:21 PM
TurboTed's Avatar
Cya
That's true, but 30 degrees is not cold enough to have any effect on the transmission, unless you make a habit of fast rough starts. Even at -30, if the transmission is slipping, something is wrong.
Old Mar 5, 2008 | 09:33 PM
billie's Avatar
Some TC's will bleed down a bit and cold justs slows the fill. If neutral fixes it, I would doubt there's a serious problem. Not that due diligence and attention are not in order for any future symptoms.
Cya
Old Mar 5, 2008 | 10:08 PM
justin mcfall's Avatar
Mine will do it in overdrive on cold mornings if i am light on the skinny pedal...
Old Mar 5, 2008 | 10:50 PM
TexAg's Avatar
Ok thanks guys. I was idling in park not neurtral, but I will definitely keep an eye on things and see if it does it again and I'll idle in neutral more.
Oh and Billie do you have a lift or level kit to run 315s?
Old Mar 5, 2008 | 10:56 PM
billie's Avatar
No all stock. Minor rub on the radius arms at full lock. Mine's an 03 though. Some guys have had to trim on later years according to posts on here.
Look great and fixed my ratio right where I wanted it.
Cya
Old Mar 6, 2008 | 07:57 PM
dozer12216's Avatar
The cold weather shift delay schedule was in effect. Trans temp is not warmed up with engine in your description. Not a problem unless was really slipping. If you still driving = not slipping. Clutch life = gone is less than a minute.
dkinzer
May 23, 2005 08:57 PM
joel
Jan 22, 2005 08:59 PM
wings
Nov 8, 2004 05:32 PM
BADodge2003
Aug 24, 2003 07:22 PM
