Tranny problem after gear swap
Old Jul 27, 2009 | 02:00 PM
BlackBomber's Avatar
Just got done swapping 4.56 gears on a truck, and now the truck wont shift into OD. Any idea why this might be?
Old Jul 27, 2009 | 02:08 PM
Totallyrad's Avatar
On the 99 you have listed in your sig or a different one?
Old Jul 27, 2009 | 04:24 PM
No, its on an 06. I need to change my sig, dont have the 99 anymore
Old Jul 27, 2009 | 04:45 PM
Totallyrad's Avatar
I'm wondering if you have to change something in the computer to tell the tranny of the difference. It may be you are further into the throttle and the computer thinks the trans is under more load and won't let it upshift. Don't give up, someone smarter than me will be along and probably know right what to do.
Old Jul 27, 2009 | 07:14 PM
no_6_oh_no's Avatar
Check for soft codes, technically it should make no difference the gear ratio because the ABS reads the signal from the ring gear not the pinion. Some trucks will throw a code because the parameters are not matching what it thinks it should and that will mess up the OD.
I take it the speedo is working and CEL is not lit?
Old Jul 27, 2009 | 10:57 PM
Yup, everything else is working properly, no CEL, and no codes per a Smarty lookup..
kujo
Aug 14, 2011 04:00 PM
Subliminal
Jul 13, 2010 09:50 AM
MR HYDROSEED
Jun 7, 2010 03:27 PM
jimlj
Sep 17, 2008 12:01 PM
gizzi
Jul 16, 2007 05:24 PM
