Tranny problem ????
Old Aug 29, 2007 | 05:07 PM
BowOnly's Avatar
Tranny problem ????
Hey guys! I have a 2004.5 Auto with about 55000 miles on it . In the mornings when the engine and tranny are still cool the transmission is acting like it is having trouble deciding what gear it needs to be in when I pull out of the driveway.... Its like it is shifting back and forth between 1 , 2 ,and 3stumbling the whole time.. After I drive it a few miles it does not seem to do it .... What gives???? Thanks....
Old Aug 29, 2007 | 06:23 PM
ArXane's Avatar
Have you checked the fluid? When was the last time you serviced it?
Old Aug 29, 2007 | 08:33 PM
donhov's Avatar
If you ahven't recently first thing you should so is to change filter and oil doing a transmission service. Then see if that helps. Manual calls for service every 30K miles.
Old Aug 30, 2007 | 08:54 AM
whiteram29's Avatar
Mine was doing the same thing recently. I've got an 05 with 64,000 miles on it. Took it in to the dealer and it wound up being the pressure governer valve that was bad. Had it replaced and it shifts good now.
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
