tranny?
Old Nov 13, 2007 | 08:32 PM
sleeperman's Avatar
tranny?
At what hp does the stock input shaft brake on a 48re? Will leaveing the line at 1500 rpm in 4wd with a smarty brake it or will the tranny be ok?
Old Nov 14, 2007 | 07:45 PM
bighornram's Avatar
Input shaft might hold if its stock. Its the torque converter and rest of the tranny that will slip if its stock. Stock input shaft can hold a wide range of horsepower - all depends on how hard you put it to the ground. 1500 RPM in 4WD will be hard on a stock tranny either way you look at it. even without horsepower upgrades.
Old Nov 15, 2007 | 11:57 AM
sleeperman's Avatar
i have a tranns go shift kit and an after market torque converter. How much will that the tranny not slip?
Old Nov 18, 2007 | 01:37 PM
BluDieselDually's Avatar
Not too much your flex plate will probably flex enough not to break your input shaft. Once i installed my bd flexplate i broke my stock input shaft twice, both times hitting small bumps in the road at wide open throttle!
Old Nov 19, 2007 | 09:47 AM
sleeperman's Avatar
ok thanks!
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
