Tps 2004 305
Tps 2004 305
I took my truck to the dealer the other day to get the tps checked out. I have been getting dead pedal when it is cold out and every once and a while. So they said well we need to reflash the computer I said ok if it will help in the diagnose of the problem. Well guess what it did not fix the problem. So here is my question is the tps under warrenty to 100 thousand since it is attached to the engine?
Contact dodge customer service with your last 8 digits of vin and get them to verify. You may need a part number, yea they want you to do most of the work. I thought the fan clutch was covered. attached to motor right, wrong not covered. $20 ujoint covered $500 fan not go figuire.
checkster
Oct 4, 2009 10:43 AM
dodgeboy59td
Dec 21, 2006 06:33 AM
