Torque Converter lockup
Old Jan 14, 2009 | 03:29 PM
dbshelton's Avatar
My torque converter doesn't lock up until at least 50mph. Is there any way to get the converter to lock up sooner? I would think that for the best fuel mileage, an earlier lockup would be best.
Old Jan 14, 2009 | 04:22 PM
tonycamacho's Avatar
Some guys use a toggle switch and over ride the lock up. This can be a problem if you forget to turn it off when stopping. I use an ATS Co-pilot control. It allows me to lock the converter at the speed I want and maintain lockup for compression braking while coming down hills with my camper and boat at tow. It unlocks prior to stopping if I forget. Again some guys don't like the ATS Co-pilot, but it works for me. I would not recommend adding a switch or a Co-pilot with a stock transmission if you want it to last.
I had mine upgraded with Triple-lock Sun Coast torque converter, Sun Coast valve body and flexplate when they rebuild the transmission. The ATS Co-pilot works great with the Sun Coast stuff.
Tony
Old Jan 15, 2009 | 05:14 AM
MiB's Avatar
MiB
Mine is locking at about 57, is there something to adjust on the valvebody to make it lock sooner.
Old Jan 23, 2009 | 03:57 AM
apprentice's Avatar
2nd gear and tow haul
Old Jan 23, 2009 | 06:22 AM
CamperAndy's Avatar
Not sure if the tow/haul is the same on your 04 but on my 06 it will lock at 25 mph in 3rd when in tow/haul mode. It stays locked in longer in 4th once it up shifts.
Old Jan 23, 2009 | 08:16 PM
Hounddog's Avatar
04 dosen't tow haul.Only O/D off.
Old Jan 23, 2009 | 09:01 PM
92'1stGen's Avatar
I see you already have an HTS valve body, if you install an aftermarket TC to go along with VB, then you won't be worrying about lockup anymore.
Old Jan 23, 2009 | 09:10 PM
rbox's Avatar
Mine locks up ~50 and unlocks if you get down under 45 or put your foot in the pedal.
Old Jan 23, 2009 | 09:55 PM
SCCSURF's Avatar
Mine dosn't lock when it should, but I'm using tow/haul in town now when I start the truck and it's keeping the temps down around 130. I don't know much about the TC switch, though it might be a fix for my issue.
Old Jan 23, 2009 | 09:59 PM
DENVERDODGE04's Avatar
mines an 04 and it says tow/haul on the dash when you hit the button.
Old Jan 24, 2009 | 01:12 PM
dbshelton's Avatar
Yep, trying to scrape up enough money to do just that.
Old Jan 24, 2009 | 04:48 PM
Megaramasaur's Avatar
with my TC switch, if i'm not getting on it, it seems to bog down too much to be effective for a fuel saving device... when I lock mine at everyday speed, it will drop my RPMS by 500 and bog
Old Jan 25, 2009 | 12:16 AM
shortbed rv's Avatar
2004 had od lockout
2005 has tow/haul that can be flashed to change it to od lockout.
2006 has od lock and tow haul.
Old Jan 25, 2009 | 07:55 AM
Hounddog's Avatar
It can say it but that's not Don't know why Chrysler started that norminclature in 04 unless it was wishful thinking that wasn't made to happen until 05 model year..Tow/haul on a 04.All it does is lockout 4th gear(overdrive} 05s it changes the valve action in the valve body and when lockup occurs.That's tow/haul. 06 up does both features.
Old Feb 2, 2009 | 01:47 PM
blakehii's Avatar
I have read forever that 04 is o/d lockout only but when my tow/haul button is on, it is much quicker, hardly any slip. I have a TC lockup switch on mine and although it does shift hard, it is not much different than it is when the tow/haul button is on. the tow/haul button definately does more than just lockout o/d on my 04.
