Torque convert on stock tranny?
Old Jul 10, 2011 | 06:38 PM
DarkPaladin's Avatar
Hey guys, I have a pretty basic stock truck. I have a Smarty Jr for towing. But I was thinking, would a new "good" torque converter be worth it, installing onto a stock tranny? Will that help me out moreso for fuel economy as well? I tow about 8k twice a year for about 800ish miles total. (Boat to Valdez and back)
Suggestions? I still some warranty on everything yet. Didn't want to tear into the tranny itself just yet.
Regards,
Old Jul 10, 2011 | 06:45 PM
Spooler's Avatar
If you do a TC then you will need to upgrade the VB. You will also need a flexplate. If you want to do just one thing, upgrade the VB or do a shift kit. Bear in mind that you have drive by wire and setting up the VB can be a pain to get it right.
Old Jul 11, 2011 | 03:53 AM
Steve-l's Avatar
Although Spooler is correct, I don't think he answered your question. Unless your TC is broken, a new one will not get you better mileage.
Old Jul 11, 2011 | 08:30 AM
no_6_oh_no's Avatar
Actually a "good" TC on a stock trans makes a BIG difference, definitely in the power area and some with the mileage. Anything that will allow more power to the ground is going to help to a certain extent.
Old Jul 11, 2011 | 01:22 PM
BPoulsen's Avatar
I'm in the same boat - trying to decide if I can just get a new T/C and VB or if I need to get the whole tranny.
If you just add the T/C and VB, can a stock trans handle it fine?
Old Jul 12, 2011 | 11:35 PM
no_6_oh_no's Avatar
Essentially, a TC and VB is fine in a stock trans. Replacing the front servo, accumulator, and billet band strut should address all the weak points. If you get a single or set up a tripple disk correctly you don't *need* a billet input.
Old Jul 13, 2011 | 12:01 AM
Spooler's Avatar
You should only need a billet input shaft if you tow with a combined weight of over 17,000lbs, drag race, or have an over 600HP truck.
Old Jul 13, 2011 | 09:10 AM
Bill M.'s Avatar
800 miles of 8000 lbs?
forget about it. stick in in tow haul and go.
Old Jul 15, 2011 | 01:12 PM
nvr-enuf's Avatar
I replaced my stock TC when 4 out of the 6 welded nuts on my TC let go. I can tell you that an upgraded TC (triple disk and tighter/less leakage) makes a WORLD of a difference in driving the truck as well as tranny temps.
I spent the weekend and 6 beers along with $1300 to change out the TC. I did not go any further since I figured that if the tranny "goes" I would simply go thru Goered and get a rebuilt one. By the time you start piecing it together (valve body, bands, etc), you are then better off biting the bullet and buying a $4000 tranny. I figure if i ever need a complete tranny, atleast I have the $1300 TC which can be deducted from the total tranny cost.
If you have the time and tools yourself, throw in a good TC - they range in price from high $600's to $1300.
That is my opinion - I am happy that I changed out the TC - should have did it the day I bought the truck.
Old Jul 15, 2011 | 03:28 PM
Sur5er's Avatar
According to the person I spoke to at Goerend, if I buy a TC and VB I can install them on my tranny and drive. She also said they will deduct those costs if I decide to upgrade to a built unit. IOW, I send my old unit with the VB and TC and they send me a complete tranny w/new TC and VB! How do you beat that deal?
Scarlet HO
19
Oct 21, 2014 01:40 PM
Redleg109
Mar 22, 2013 01:05 PM
Alexd
Dec 2, 2004 06:39 PM
nwilliams98
Apr 19, 2003 10:45 AM
hellotbone
Mar 20, 2003 07:14 AM
