Titanium in oil sample
Old Feb 27, 2013 | 11:21 AM
N.Johnson's Avatar
Just got back my report. All numbers normal according to years of sample reports except titanium is 18 ppm and iron is 22 ppm. Only change made to the motor is a new turbo install and oil was change at the time. The sampled oil had about 7500miles/250 hours on it run over the winter season. Question is where is titanium coming from? Valve seat or the shaft of the new turbo?
Old Feb 27, 2013 | 02:32 PM
pdogg's Avatar
Could be normal, in your oil.
from Bobistheoilguy.com
Titanium is a newer, more environmentally friendly anti-wear additive being implemented due to more stringent emissions regulations, and is phasing out the older, more harmful phosphorous compounds such as ZDDP (Zinc dialkyldithiophosphate). ZDDP reduces the effectiveness of the catalysts in catalytic converters by creating a plating effect when combusted, and covering the catalyst while Titanium does not. Titanium chemically binds to wear surfaces creating a hard, Titanium based oxide layer which reduces friction, thereby reducing wear. Concentration levels vary greatly depending on oil brand.
http://www.bobistheoilguy.com/engine-oil-analysis/
Old Feb 27, 2013 | 02:58 PM
N.Johnson's Avatar
Thanks for replying. The oil I'm using is valvoline PBS 15w40 as always? Has valvoline started adding titanium? Do the valves or seats on my motor use titanium or any metal in the motor for that matter? Can't find the answer.
Old Feb 28, 2013 | 05:25 AM
Snowdog's Avatar
I wouldnt worry about it. I use Valvoline Premium Blue 15W-40 and at 130,000 miles,bone stock with 10 k on oil my titanium was 28 ppm.Runs great.
Old Feb 28, 2013 | 02:40 PM
N.Johnson's Avatar
I have never had a titanium reading from oil analysis with the same oil. What or where do you think it is coming from?
Old Feb 28, 2013 | 05:02 PM
Snowdog's Avatar
Thumbs up
I just received my new oil analysis from Blackstone. Titanium is at 28 ppm again. I think its an oil additive as was stated before from "Bob the oil guy" article.Blackstone said my engine is doing great and they are not concerned and I am not either. Maybe you could email Valvoline to see if they use that additive.I think you are OK.
Old Mar 1, 2013 | 08:18 PM
wellmax's Avatar
i use shell rotella 15w40 because it was my understanding it had higher zinc levels.
but as others have said they may have to take the zinc levels down due to epa rules.
my old dodge and fergy tractor run great on shell rotella
Old Mar 3, 2013 | 04:25 PM
N.Johnson's Avatar
That interesting....do you run the stock turbo or have changed anything in the motor?. Only change I made was the turbo since the last oil sample results.
ctd4stan
May 5, 2011 10:39 PM
pmtg
Jan 17, 2006 09:45 PM
jon96ctd
Dec 5, 2005 09:11 PM
adamlangs
Apr 14, 2005 11:55 AM
dssimecek
Feb 16, 2005 12:28 PM
