tires balanced and rotated
Hover over the guy and insist the readout says "zero" as he adds,adjusts weights.
My truck experienced dw after a botched rotation and rebalance(one tire was 4 ozs. off). I returned to the tire dealer and different guys rebalanced them. End of problem. This was no error,it was sabotage. I think it was the guy's last day.
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
"No! It also occurs on trucks that are factory stock."
Doc,
Is there a particular year when the wobble started ?
I've replaced ball joints and axle joints on mine and I noticed my tie rods and front end parts etc are almost twice the size of the newer stuff. Is it because of the chintzy parts on the newer ones maybe ?
Doc,
The "Death Wobble" as it is referred to, started to occur in the second generation trucks.
There are a multitude of components that can cause this anomaly and I suspect that product quality may be a contributor. For example, I find that ball joints are not something to go the cheap route on. I no longer use the brand found in most typical parts stores and have since gone with Carli.
I have attached a link that will provide you with a great deal of insight into the death wobble issue. This is not something that can be easily diagnosed, because the fix for one truck may be totally different than another.
https://www.dieseltruckresource.com/...e-t304365.html
Big Horn 06
Sep 21, 2007 06:01 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
dssimecek
Jan 24, 2006 09:49 AM
