third brake light
Old Mar 9, 2012 | 06:11 AM
WKD's Avatar
WKD
third brake light
My third brake light dose not work. bulb is good and cargo lights work,brake lights on box work fine. is there a fuse for over head brake light. thanks
Old Mar 9, 2012 | 10:51 AM
Shorts's Avatar
"Center High Mounted Stop Lamp" or CHMSL as the service manual says. I have the wiring diagram here. If I can figure out how to get it to you...
The fuse looks like #26 (15A). But I don't think that's your problem. If it was, you wouldn't have the cargo lights or any brake lights as the brake light switch is after the fuse as well. The wire color going into the stop lamp is WT/TN which I'm guessing means white and tan. But that also supplies the cargo lights and you said they work.
I'm wondering if the bulb socket itself is the culprit.
Anyway, got a few things to do but I'll try to get this page in a format I can get it to you.
Old Mar 9, 2012 | 12:34 PM
ssandlin's Avatar
I believe wiring diagrams can be found here
http://www.rambodybuilder.com/year.pdf
stratos201proxl
Jan 16, 2014 11:04 AM
mjsandt
May 31, 2006 09:52 PM
tmacie
Mar 15, 2006 11:08 AM
loggertruck
Dec 18, 2004 08:51 PM
MR. GADGET
Feb 24, 2003 10:24 PM
