think I got a burnt valve
Old Jun 11, 2007 | 07:03 PM
bigsilver's Avatar
hello everyone,
Haven't posted lately been busy. My question is what are some of the symptons for having a burnt valve and how commonly does it happen.
Old Jun 11, 2007 | 07:23 PM
53 willys's Avatar
running lean=burnt valve
Old Jun 11, 2007 | 07:53 PM
Hounddog's Avatar
Never read or heard about one of these burning a valve.Now a dropped valve seat is common.
Old Jun 11, 2007 | 08:15 PM
BigBlue's Avatar
What makes you think you burned a valve?
Old Jun 11, 2007 | 08:51 PM
PoorMansCat's Avatar
A burnt valve can usually be found as a "dead" hole. Low exhaust temperature at that port on the manifold when shot with a temperature gun. Can also show up as an abnormal noise coming from intake or exhaust, or as "wet stacking" from raw fuel being thrown into the exhaust. Either way, its a bad thing. Not sure if anybody makes tooling for running a compression check, but if there is, you can run a compression check on the suspect cylinder, if its low, squirt a SMALL amount of oil in it and re-check. If it comes up, its usually rings, if it doesn't then its usually a burnt valve.
doorguy
Feb 15, 2009 09:07 PM
woodrep
Sep 15, 2007 06:14 PM
Joseph H. Smith
May 12, 2004 10:07 AM
thumper 549
Jul 14, 2003 06:58 PM
deuceandahalf
Nov 14, 2002 12:05 AM
