G56 clutch problums
Old Jun 9, 2007 | 01:19 PM
RAMRODD's Avatar
G56 clutch problums
Well after 30,000 miles looks like my first problum is going to be the clutch.
What do you think is wrong, when I get on it hard and push in the clutch sometimes the clutch is twice as hard to push in. I am kinda thinking throw out bearing, but their is no noise. clutch doesn't slip unless I want it to
I want a DD southbend clutch where is a good place to get one??
And here I was going to go to a sled pull tonight
Old Jun 9, 2007 | 01:39 PM
DmaxEter's Avatar
Mine does the same thing. Has been like that for about the last 20,000 miles!
Old Jun 9, 2007 | 02:05 PM
RAMRODD's Avatar
How many miles on the truck? I notice that when it pushes hard that it doesn't release as good as it should.
I really want to enter tonight but it is not worth the clutch flying apart and wrecking something else.
Old Jun 9, 2007 | 02:11 PM
Danderson's Avatar
"Scratchy" clutch feel
Mine's been doing a weird thing lately. When I initially push in the clutch it feels silky smooth. After a few engagements, however,it feels like something's rubbing against bare metal. Clutch engagement is smooth,it just seems like the mechanism is rubbing or something. This is on the downstroke only.
Old Jun 9, 2007 | 02:18 PM
RAMRODD's Avatar
That is what mine is doing!! Still makes me think trow out bearing or mabey something is even wrong with the hydrolic assembly??
Someone here must have taken their truck to the dealer to get it fixed.
Old Jun 9, 2007 | 05:57 PM
tbarbee1's Avatar
I think you can get one from Larry here at the DTR store. If not call Peter at southbend.
Old Jun 9, 2007 | 06:00 PM
mrblond's Avatar
a leaky or sticky mast/slave cylinder can give this screwy feed back thru the peddle
Old Jun 9, 2007 | 07:20 PM
Danderson's Avatar
Dealer dread.
Thanks,I've got a squeak upon starting cold that dissappears in a few minutes that I want them to look at too. Only problem is I hate taking it in.
Old Jun 9, 2007 | 11:54 PM
RAMRODD's Avatar
How do you test if the slave cylinder is bad??
What is so special about the sprung hub double disc from South Bend??
On a side note I saw a 2007 6.0 powerstroke win the sled pull tonight
Old Jun 10, 2007 | 09:31 AM
mrblond's Avatar
replace them one at a time.
I am also interested in the SB H/W and all part #'s
Old Jun 10, 2007 | 09:56 AM
RAMRODD's Avatar
I wonder if I could instal a heavy duty hydraulic assembly From SB on to the stock G56 clutch? At least then if It doesn't fix the problum I have a part I am going to need anyways. I will have to give them a call on monday.
Old Jun 10, 2007 | 10:11 AM
tbarbee1's Avatar
I dont see why not. Wait a minute though peter said the Hyd. upgrade is not to make the clutch easier but it actually changes the way the clutch engages. Something about the stock Hyd. would not even disengage the DD I think the lenght is different. Call him andlet us know????
Old Jun 11, 2007 | 11:02 PM
RAMRODD's Avatar
I called and talked to peter at South Bend about the hyd upgrade while using the stock g56 clutch and he said it will work. At least if a guy is going to trouble shoot you can put on a quality upgraded part!!
I decided to order the hyd upgrade and the 3600 sprung Hub DD
Old Jun 11, 2007 | 11:07 PM
ssleeper94's Avatar
slave cylinder, mine did the same thing, i'm on number 3 w/ 40k on it, i just gotta get the the sbc and hydrolic upgrade and be done w/ it
RAMRODD
Jan 16, 2011 06:20 PM
arcticmudpro
Apr 26, 2010 06:26 PM
duffer26
Oct 6, 2007 11:43 PM
RAMRODD
May 29, 2006 09:35 AM
