burnt valve
Old Dec 24, 2008 | 12:19 PM
doorguy's Avatar
burnt valve
I think I have a burnt valve.Had 2 cracked injectors and all six had forienge material in them.Truck had a pop sound at the exhaust was just hoping it was injectors no such luck. Will have to do more checking before it gets tore apart.
Old Dec 24, 2008 | 12:33 PM
torquefan's Avatar
If you have any sort of problem that causes low compression in one cylinder, disable the injection so the engine can't start, then crank the starter. You should be able to hear a weak cylinder while cranking.
Old Dec 24, 2008 | 05:28 PM
Hounddog's Avatar
Valve probably not burnt but has a dropped valve seat.
Old Dec 25, 2008 | 10:50 AM
Jeff in TD's Avatar
I think I'd check the valve gaps. If one is way out of wack...
Old Feb 15, 2009 | 09:07 PM
sallyman1's Avatar
i did this also. they all were pretty close. i changed all 6 injectors myself and did valve set. i still have sound and white smoke from exhaust.no air or smoke coming out of oil fill cap hole?
woodrep
Sep 15, 2007 06:14 PM
bigsilver
Jun 11, 2007 08:51 PM
Joseph H. Smith
May 12, 2004 10:07 AM
thumper 549
Jul 14, 2003 06:58 PM
deuceandahalf
Nov 14, 2002 12:05 AM
