Is there a good inline fuel filter I can put before my canister mounted pump?
Old Sep 12, 2009 | 01:38 PM
Dodgezilla's Avatar
I have an 04 w/ the filter mounted fuel pump. I know everyone here, including me, tries to filter as much junk out of the fuel before it hits the pump. If I buy the replacement pump from Genos then it comes with the little silver canister type fuel filter. Is that one the best I can get without buying some $300 setup that requires hours to install? My pump works fine and I have a spare that does too so since I don't plan on BOMBing anymore I want to keep my LP as healthy as possible. There is a length of hose right before the pump where I could install one like Genos uses but I'm wondering if there is a better one out there...
Please don't tell me to get a Raptor, or Fass, or Walbro setup. I just want to know if there is a good filter I can use that won't give me problems.....
Old Sep 12, 2009 | 01:57 PM
mini14's Avatar
wix 33270 its a wire screen 3/8" fittings, non restrictive. i used it before i added a pusher pump and cat 2mic, the 33270 caught a lot of junk, but it just doesnt have capacity like a true ff. and i think its 120 micron.
Old Sep 12, 2009 | 02:00 PM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
I get real weary of the.."Fass, Raptor, Walbro schmutz all the time. I'm just a stock trucker and don't quite need the capacity to pump out my swimming pool in 15 minutes. I replaced my canister pump at about 75g's with Geno's replacement (not because it went out but I noticed with the fuel pressure gauge it dropped from around 9-10psi down to about 6-8psi.) I use a Napa #3270 inline (small silver filter)+a Baldwin in the canister with the new pump and it is back to 9-10psi. Every other filter change I change the Napa filter. 110g's now and still running like supposed too.....I guess I don't see the impending need to change the set up lest a great fuel disaster looms just below the horizon just waiting to reek havoc on my Fiat Ram.
Old Sep 12, 2009 | 02:01 PM
mini14's Avatar
napa 3270 is wix 33270
Old Sep 13, 2009 | 06:39 AM
Dodgezilla's Avatar
Thanks guys. I'm gonna buy a couple and put them on the shelf right next to my other filters. I don't see a need for a better LP so I too am just gonna keep running the stocker. As I said, I keep a spare in my truck since it's pretty easy to change.....
Old Oct 2, 2009 | 07:24 AM
BLACKBEAR's Avatar
If you will add Oz of outboard motor oil to you fuel this will let you pump last longer and let your Eng run quieter. I have been doing it for over 2 years and it has help my fuel millage a little. I use super tech TC w 3 Wal Mart oil Give it a try. You know that it is used in snowmobile in -40 and the gas does not freeze up with a 40:1 mix so you know it good to go. Do NOT use it in an 07 up that is already designed for the ULSD fuel
dsleight
Oct 19, 2009 08:31 AM
Camarokid77
Jan 29, 2009 01:12 PM
HorseHauler
Oct 4, 2006 03:39 PM
Javahjoeo
Mar 28, 2006 07:57 PM
TerryS
Sep 18, 2005 03:33 PM
