Tank vent recall/ flashes for 06 questions
Taking my truck in tomorrow to do the following:
tank vent recall
High idle enabled
Latest flash
My question is...should I have the recall performed, and should I get the flash done? I've seen posts on the forum about the tank vent recall but unclear if this is something I should do myself, or allow the dealer to do?
On the flash, my goal is to get better gas mileage and hopefully get the transmisson shifting a little smoother. Any had an experience with the latest flash for the 06? Should I even mess with it?
Thanks in advance!
tank vent recall
High idle enabled
Latest flash
Thanks in advance!
I had the flash done because I kept getting codes for temp irrationality when using my block heater.
My idle went up a little higher, my fuel mileage went up 1-1.5mpg, make sure you bring all your keys, they'll have to reprogram them.
I have yet to let them flash mine as I have not had any codes and I get good fuel mileage. I worry if they do flash it I lose mpg like I've heard of happening to a few others. But then they should of taken care of all those problems by now, but I still think if its not broken leave it alone.
Flash # 35325533AS includes
TSB 18-001-07 (Engine control for P2502, P2503, P2509 codes)
TSB 18-003-06 Rev A (Long crank, 48RE Shift improvement, Battery charging)
TSB 18-005-06 Rev B (Irrationality codes, Cold turbo protection, Clutch protection)
TSB 18-032-06 (Engine Controls for P0109)
TSB 18-041-05 (White smoke, Fuel economy)
97catintenn
Aug 7, 2009 08:23 PM
pet05
63
Jan 10, 2009 10:30 PM
glocklove
Nov 14, 2008 09:51 PM
rjm022
Sep 30, 2006 05:11 PM
