in-tank lift pumps: truth, myths, speculations, lies.
Old Dec 19, 2007 | 03:42 PM
  #136
Bark's Avatar
I get so confused. Truck has 69kmiles. I just pull my trailer with it. Stock LP still seems strong. I dont intend to ever put any mods on it. Without rehashing or re-starting any debates--if the LP does start going, what would be my best option for replacing it.
Old Dec 19, 2007 | 03:46 PM
  #137
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
you have an externally mounted pump..... unless you got the retrofit by the dealership to an intank pump.
your choice what you want to do. id just carry a spare and have a decent pressure gaure on your truck
Old Dec 19, 2007 | 07:16 PM
  #138
gmctd's Avatar
If your CP3 doesn't have the lift pump on the back of the high-pressure pump, it will not draw fuel from the tank - see also my thread on CP3 operation -
https://www.dieseltruckresource.com/...d.php?t=173104
Old Dec 19, 2007 | 07:57 PM
  #139
Bark's Avatar
Sorry, should have posted my above question in a new thread but appreciate the response. Guess the bottom line is, would I be better off getting the retrofit prior to warrenty expiration (i know the LP can fail if I "will" it) or do you think I would be better off continuing with my external set up (esp if I carry a spare).
Old Dec 19, 2007 | 08:21 PM
  #140
gmctd's Avatar
No apology necessary, dude - the posted pic is just enhanced info for this thread, not intended to single anyone out.
Show'n'tell uber alles!
IMO, if DCX has no reason to replace the oem Carter under warranty, the easiest option is to get a spare replacement duplicating what is already there, or get the upgrade version from Geno's garage, as some have found that oem Carter to be discontinued by DCX - that will be the easiest to replace on the side of the road when the oem lp fails, wouldn't you agree?
Old Dec 19, 2007 | 10:16 PM
  #141
realsquash's Avatar
Not sure if you're addressing me, but I do have the in-tank retro-fit.
Andy
Old Dec 19, 2007 | 10:33 PM
  #142
Bark's Avatar
Thank you gmctd. Guys, correct me (please) if I am wrong. As I understand it, the in-tank set up is more reliable and slightly more efficient than my current stock LP but the external LP is far easier to work on.
My question should have been: For my stock truck, if given the option--A: Would you rather have the dealers in-tank conversion or-
B: the external replacement pump from Geno’s.
My current plan (unless it changes) is to order the external one from Geno's to keep in the trailer unless you guys feel the in-tank set up is better in the long run.
Thanks again for your input.
Old Dec 19, 2007 | 11:58 PM
  #143
ddestruel's Avatar
nope i was directed at bark.
in bark's case i would keep what works and wait. mine got the tank pump 30 days before the warranty expires due to the "dealership determining the pressure and flow were low"
i would carry the spare in the truck.
Old Dec 20, 2007 | 12:59 PM
  #144
Red-Goat's Avatar
the inlet on top is the CP3 supply line..you need to flip your labels
You have to go back a few posts to page 9 to see this.
Do I have this labeled wrong?
hamilton71801
Mar 5, 2010 09:14 AM
kallen
50
May 23, 2009 12:16 PM
BearKiller
Dec 23, 2007 10:47 AM
GSP
Jan 5, 2006 07:16 AM
Mopar1973man
Sep 6, 2005 07:01 PM
