Tail Shaft housing boot Help???
Old Sep 1, 2008 | 04:31 PM
bluechrome's Avatar
I've been leacking fluid from my tailshaft housing boot. I don't know why it started leaking after I replaced the u joints in my d-shaft. WHat do I need to replace to fix leak and how hard is it? Should I change My t-case oil as well? If so What is the process and how much fluid?
TIA
Old Sep 1, 2008 | 10:38 PM
kawiram's Avatar
probably damaged while re-installing the DS. Here's the how to.
1. Raise and support vehicle.
2. Remove rear propeller shaft. (Refer to 3 - DIFFERENTIAL
& DRIVELINE/PROPELLER SHAFT/PROPELLER
SHAFT - REMOVAL)
3. Use a suitable chisel or pry tool to remove the rear
extension housing dust boot (2).
4. Use a suitable chisel or pry tool to remove the rear
extension housing seal.
INSTALLATION
1. Clean fluid residue from sealing surface and
inspect for defects.
2. Install the extension housing dust boot and seal
assembly with Installer 9037 (3) and Handle
C-4171 (2).
3. Install propeller shaft. (Refer to 3 - DIFFERENTIAL
SHAFT - INSTALLATION)
4. Verify proper transfer case fluid level.
5. Lower vehicle.
DR/DH TRANSFER CASE - NV271 - SERVICE INFORMATION 21 - 1419
FLUID
STANDARD PROCEDURE - FLUID DRAIN AND REFILL
The fill (1) and drain (2) plugs are both in the rear
case.
1. Raise vehicle.
2. Position drain pan under transfer case.
NOTE: It may be necessary to remove the exhaust
y-pipe at the exhaust manifold to properly access
the fill and drain plugs. Lowering the exhaust will
allow the plugs to be accessed for torquing during
installation. (Refer to 11 - EXHAUST SYSTEM/EXHAUST
PIPE - REMOVAL)
3. Remove drain and fill plugs and drain lubricant
completely.
4. Install drain plug. Tighten plug to 41-54 N·m (30-40
ft. lbs.).
5. Remove drain pan.
6. Fill transfer case to bottom edge of fill plug opening
with MoparT ATF +4, Automatic Transmission fluid.
7. Install and tighten fill plug to 41-54 N·m (30-40 ft. lbs.).
8. Install the exhaust y-pipe to the exhaust manifold, if removed. (Refer to 11 - EXHAUST SYSTEM/EXHAUST
PIPE - INSTALLATION)
9. Wipe any excess fluid that may have spilled onto the exhaust.
10. Lower vehicle.
Old Sep 2, 2008 | 09:00 PM
bluechrome's Avatar
So it seems as thow I damaged the seal behind the dust boot? Where Can I get this Seal. Thanx for that info
Old Sep 3, 2008 | 12:00 AM
kawiram's Avatar
Not sure if its a dealer only item, check the parts stores I guess. If not, then I think this might be the part.
https://www.dodgeparts.com/oe_parts_...157a94a6fd1639
Old Sep 4, 2008 | 08:02 PM
Virginia Diesel's Avatar
I have had my 06 Dodge 3500 in the shop many times for a leak, and had a boot replaced and was told this was the problem. ONLY to find out now that they tell me it's the Transmission Tailshaft Housing Leaking and cost to replace is $737 (parts, labor, and tax). I have 63K miles on my 06 and have had it in the shop many times for leaking.
What other options do I have for fixing this problem?
Old Sep 5, 2008 | 12:00 AM
kawiram's Avatar
Va.Diesel Please fill out your Signature so everyone knows what your truck is equipped with. Have you crawled under to see exactly where its leaking from? Could still be the seal, maybe your slip joint has a burr or nick, and damages the seal when the DS is re-installed.
pcgym
Feb 15, 2010 03:47 PM
95black2615
Oct 8, 2008 03:34 PM
Trooperthorn
May 25, 2008 01:27 PM
turbo6justin
Jan 9, 2006 01:54 AM
turbo6justin
Jan 8, 2006 05:51 PM
