Tach jumps while idle?
Old Mar 26, 2010 | 10:09 PM
estesbubba's Avatar
For about a year now, my tach will jump anywhere between 400 - 700 rpms while idle. Doesn't matter if it's in gear or N. After taking off it will fix itself after a few seconds and reads just fine while cruising. When idling I can tell the engine isn't changing RPM's but it's annoying to see the tach jump. Anyone else see this and is it an easy/cheap fix?
Old Mar 26, 2010 | 11:05 PM
reisenbise's Avatar
mine did same thing, now in shop for new inst. cluster
Old Mar 27, 2010 | 08:54 AM
KWKING's Avatar
Mine too,this problem is clearly on 06s only so its obviously a manufacturing defect in the cluster ,I dont see why any of us should have to pay for it.Every time I ask my dealer about it he plays dumb,and says it will be about $150 just to diagnose it,there are so many bad tachs on 06s it would have been a recall issue if it were a safety issue.Its things like this that make for unloyal customers!!!!But Dodge is cheap cheap cheap so they wont give in.Without CUMMINS Dodge is truly worthless.
Old Mar 27, 2010 | 10:38 AM
etn550's Avatar
Yep mine too. It's getting worse and doing it all the time, including when driving. I can not trust the reading now. Sometimes it goes to 100 rpm.
I have another thread going on this problem. After Easter I am sending my cluster to "Mr. Whizzard". Google them. I e-mailed them and they think they can fix it and just started a standard repair for the problem where the '06 Dodge tach winds all the way around the dial. Their charge is $175 including shipping both ways and a 2 yr warranty, 2 weeks turnaround. As soon as mine is back in the truck I will report the results. stay tuned!!
I really like this option since no one has to reprogram the odometer mileage in the cluster when it is changed.
Old Mar 27, 2010 | 12:53 PM
KWKING's Avatar
Does anyone know what the warranty is on a new cluster?and have they even identified the problem,what concerns me is if I buy a new one and six months from now the same problem occurs on the new one.Mine is out of warranty so I have to pay for a new one.I am an ex electronics tech,if I still had my freq. generator and a decent schematic diagram of the cluster I'd give fixing it a whirl too.Dodge should be fixing all of these for free,a tachometer does not wear out like ball joints ,shocks, bearings and other mechanical parts.It obviously is a manufacturing problem.
Old Apr 1, 2010 | 12:53 PM
scoutman's Avatar
Same problem here. I don't even pay attention to the tach except for a good laugh when it goes spinning to the bottom side of the peg. It's like it's possessed...
Brad5502
Jul 8, 2008 11:19 PM
boyd050
Apr 27, 2008 02:47 PM
hvanflee
Jul 12, 2005 08:14 AM
Turbo Deeezle
Dec 2, 2004 08:36 PM
furious70
Aug 5, 2003 11:26 AM
