sweaty common rail
Old Jul 30, 2005 | 03:37 PM
swansong04's Avatar
sweaty common rail
was driving home from homedepot/costco this monring and when i was coming up the hill to where i live ,i had the a/c on and i could smell diesel fuel odor coming through the vents .. when i got home i checked under the hood to find that the common rail was very , very sweaty with diesel .. it goes into the ******* on tuesday for a quick look .. have any of you ever had this problem , or know what causes it ???
thanks for any info
Gary
Old Jul 30, 2005 | 06:01 PM
PourinDiesel's Avatar
Maybe a loose line?
Old Jul 30, 2005 | 06:14 PM
Hounddog's Avatar
I have looked under the hood of a number of 03s up and see the lines at the injectors somewhat damp if that the right wiord.Mine gets that way also.Can clean it and residue starts appearing fairly soon(days).Curious to what is said about yours.
Old Jul 30, 2005 | 07:33 PM
swansong04's Avatar
thanks for the input .. i'll let you guys know on tuesday night !!!
Gary
Old Jul 31, 2005 | 12:38 AM
gatf4's Avatar
I had the same problem with mine. I had the fuel pressure sensor go bad when the truck was 3 weeks old. The sensor mounts right to the fuel rail in the middle of the engine. The dealer replaced it under warranty but had to order the part. Good luck
Old Jul 31, 2005 | 10:42 AM
DDahl's Avatar
I had the diesel smelling common rail on my 2005. The problem turned out to be loose connections to the injectors (both inner and outer nuts going into the head on all six injection lines). You need to have the lines tightened up by a good mech. After mine were tightened, no more dust etc. Also the engine now has much less minor knocks and rattles. The mech. said that the loose connections often lead to a no-start situation. Also the problem of loose lines is relatively common.
Old Jul 31, 2005 | 06:02 PM
Dodgezilla's Avatar
I had that happen when I ran my EZ on level 5 which raises the rail pressure pretty high. There's a $1.00 o-ring at the pressure relief valve that had gone on mine. Fixed in two minutes. I'd recommend removing your Quad box before taking it in to a dealership....
Old Jul 31, 2005 | 09:36 PM
swansong04's Avatar
yup she's already off and hidden in my shop!! just out of the veiw of te dodge police !!! hehahe... i sprayed the swaety areas with some brake clean and she looks brnad new angain .. and 24 hours later it still looks good ... .. i am hoping it will sweat again . cause i don't wana the dealer to say nothing is wrong .......
Old Jul 31, 2005 | 09:47 PM
MOREPOWER's Avatar
Mine was leaving big spots it was leaking so bad. The dealer just tightened the fittings and all good.
Old Aug 2, 2005 | 06:41 PM
swansong04's Avatar
well back form the dealer ..turned out to be a washer under the fuel pressuer sensor .. all is good now .. they also replaced door seal # 3 on the passenger side ..
G
Old Aug 3, 2005 | 03:48 AM
Dodgezilla's Avatar
You're welcome.......
NJTman
Apr 7, 2013 07:02 AM
ddestruel
Jun 28, 2004 01:03 PM
spots
Mar 18, 2003 07:14 PM
Berak
Feb 10, 2003 08:48 PM
