swap 48re for 47re?
Old Apr 13, 2009 | 12:30 PM
Arlon's Avatar
swap 48re for 47re?
I have one of the early 03's with a 47re. Can I simply swap it out for a later model 48re? Any difference in wiring, etc?
I am considering replacing it (47re) with a rebuilt and would like to get the best towing tranny I can afford.
Lower stall converters of any value while I'm at it? No big mods, just towing an 8000lb 5th wheel.
Old Apr 13, 2009 | 01:10 PM
HotRodTodd's Avatar
The 47/48 is a direct swap no problems.
A better converter is a must have while the tranny is out.
You might consider an aluminum high capacity pan also, it will help cool the trans, and stiffens up the case a bit too.
Old Apr 13, 2009 | 02:42 PM
SOhappy's Avatar
Probably cheaper to have the 47RE built for towing (suncoast, et. al.)
and would end up stronger than a stock 48RE too.
Old Apr 13, 2009 | 03:19 PM
'strokeThis_'07's Avatar
I believe the 03-04s have a TV cable, while the 05(?) and later trucks are all electronic on that front
You can put the majority of the 48s internals into the 47. Not all, but most of them
Old Apr 13, 2009 | 06:10 PM
no_6_oh_no's Avatar
Doesn't matter. The TV motor just drops on top of the same lever theTV cable setups used.
All of the 48RE parts will fit into a 47, as long as the correct dependent pieces are used.
If you can find a 48RE to buy reasonable it will work fine. If not, buy the parts to upgrade it and you will be good to go also.
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
RAMMANX2
31
Mar 5, 2003 09:55 AM
paward
Jan 31, 2003 04:04 PM
FireNhole
Dec 7, 2002 04:39 PM
