Surging at 60-70 mph, out of options need pointers
Old Aug 12, 2020 | 06:21 PM
mkingan's Avatar
i have a 2007 crew cab 5.9 ram 2500. It started surging and has cont. to do it. I have changed the pickup, flushed fuel system, new fuel filter, trans filter change. also changed Fuel Control Actuator and new pressure relief valve. I was having hard starts but once the Fuel Control Actuator was replaced it starts perfect. No issues on fuel pressure or idling but once you get going down the road between 65-70 it will start surging. I tried turning off the OD but made no difference. Where can i go from here? Also not one single code thown
Old Aug 13, 2020 | 08:57 AM
FMB's Avatar
FMB
OK, your's is an '07 and my old RAM was an '03. On the '03, I would make sure to pull and clean the Mass Air Sensor located on the intake manifold (special aerosol cleaner for this) and the Inlet Air Temperature/Pressure Sensor. If that didn't help, it may be time to have the injectors tested. How many miles on your truck?
Back to morning brew . . .
svtrich
Jun 11, 2020 06:22 AM
Inline_6
0
Dec 18, 2017 06:20 PM
weebo134
Aug 16, 2017 12:11 PM
kodeman84
Aug 7, 2011 08:46 PM
bkoz
17
Oct 18, 2009 09:32 PM
