Strange Tow/haul issue
My 06 CTD has developed a curious issue after the last time I towed my boat. The truck has about 5K miles on it so far. While towing my boat, I set the tow/haul/OD to tow/haul and had zero troubles.
A few days after I have noticed that sometimes my Tow/haul button will not function. Meaning, I can press the button (while dirivng and in D) all I like but the tow/haul or OD lock modes will not light up on the dash and I cannot feel the tranny's shifts change.
If I stop the truck, place it in park, turn the motor off, wait for a few mintues and fire it back up then I get the Tow Haul mode back.
My only mod it the Edge Juice/ATT and I do leave the stock defuel setting ON for tranny slipage. I have tried removing the Edge but it does not solve the issue.
I should also note the truck is not driving any different (meaning, no detecable mechanical tranny problems or driving problems). Also when I get the Tow haul mode back and the lights come up on the dash I can feel the shift points change and such.
I am getting the feeling there might be a back switch somewhere (meaning I bet its an electrical problem). Any solid ideas before I let the dealer look at it?
NOPE--- You can push the button at anytime while driving!! You can also push the button again while driving and make the Trans go into O/D Lockout- - - - - which is REAL BAD at 65mph/70mph!!!!! Sounds to me like there is a glitch in the programming of the truck from the factory-----take her in and let the dealer scan the ecm to see what is wrong! Be sure to take the EDGE off before you do this.
