Stock turbo for 04?
Old Apr 29, 2008 | 09:40 AM
sixb's Avatar
Stock turbo for 04?
What are the #s (example 60/14) for a stock turbo, no electronics. It's off a 2004 cummins?
I was told they are like the hybrids HX35/40.
Also what is the exhaust housing size?
And are they the same for auto and the manual?
I am thinking of buying a used one for my k5 repower, I already have a 03 manifold.
Thanks.
Old Apr 29, 2008 | 09:50 AM
soulezoo's Avatar
DTR 1st Sergeant
They are HE341w. Same for auto or man.
they have a 9cm EH. They are not like a HX35/40 hybrid (HE341w is slightly smaller)
Not exactly sure, I think they are 56mm inducer. HX35/40 hybrids can be 58-61mm inducers.
Old Apr 29, 2008 | 09:52 AM
soulezoo's Avatar
DTR 1st Sergeant
For what it sounds like you want it for, it will probably work very nicely.
Old Apr 29, 2008 | 01:48 PM
sixb's Avatar
I guess if the newer trucks don't have any egt issues at stock levels I should be good to go with a 92 5.9 tuned for about 250 hp on the ground. The 04 turbo I guess would produce a very fast spool and no somke, and that is good. Thanks.
Old Apr 29, 2008 | 02:38 PM
sixb's Avatar
Sounds like an hy35 on the 01 and 02 autos.
Old Apr 30, 2008 | 03:33 AM
mostly stock's Avatar
sorry for the hijack, think i asked this before but...
what are the numbers on the turbo discreptions stand for eg 65/14
Old Apr 30, 2008 | 10:10 AM
soulezoo's Avatar
DTR 1st Sergeant
It is common here on this forum to describe a turbo by its inducer size/compressor (or exducer) size/then Exhaust housing size. Example an HTT turbo that is 62/71/13ss equals a 62mm inducer/71mm exducer/ 13cm EH (the ss stands for stainless steel) This helps to compare similar turbos in terms of size. There are other meaningful and important things not mentioned with these numbers... the A/R ratio of the compressor and exhaust housings for instance.
Old Apr 30, 2008 | 10:47 AM
tell me more
Old May 1, 2008 | 04:37 PM
gus's 03's Avatar
Originally Posted by mostly stock
tell me more
http://www.turbobygarrett.com/turbob...o_tech102.html
jaconst
Aug 16, 2014 11:00 AM
D45
Aug 11, 2008 12:26 AM
jgiachino
May 12, 2008 02:06 AM
Robert P
23
Mar 1, 2007 12:21 PM
Lark
18
Feb 12, 2007 06:34 PM
