steering clunk
Old Jun 5, 2007 | 03:41 PM
plug ugly's Avatar
steering clunk
every so often I get a clunk when turning. This is on an 07 quad with less than 600 miles. is this a normal part of the axle/hub/4x4 set up the dodge uses, or is this indicative on some other issue
Old Jun 5, 2007 | 05:05 PM
Sevir's Avatar
2 or 4 wheel drive. this is a known issue with 2WD. you have to grease the knuckle where it bumps the linkage. You will see it if you look under the truck while you have someone turning the wheels.
Old Jun 5, 2007 | 11:05 PM
plug ugly's Avatar
4wd. Its mid turn and inconsistent. Ill look into tho, thanks
Old Jun 6, 2007 | 05:22 AM
kry226's Avatar
Try tightening the track bar where it bolts to the frame on the driver's side. Torque that sucker. Worked for me.
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
93Dodgeman
Jul 26, 2006 08:04 AM
dpeder
Feb 21, 2006 11:34 AM
