steering box/ track bar help
Old Jun 20, 2009 | 09:42 PM
bcfreighttrain's Avatar
what are the signs that the steering box is getting worn out? i am on my 2nd upgraded tie rod/drag link set up in two weeks(ball stud on passenger side was defective on the 1st one) and have since put in an aftermarket steering box stabilizer and new sway bar end links (shortened procomp 5" end links) and the steering still isn't the same as it used to be. wandering at highway speeds so i am just trying to see if anyone has had these issues. also the ball joints are good so maybe the factory track bar is starting to get worn and contributing to wonder at highway speeds?? the frame end of the track bar has a little bit of lateral movement but the bolts are tight, maybe the bushing or bolt hole is little worn.... truck has just over 100,000kms on it
Old Jun 27, 2009 | 05:40 PM
BLACKBEAR's Avatar
You need to go to www.genosgarage.com they can help you out jest talk to them. Tell them what you have done.They have a Bergson steering shaft that is a lot better than the dodge and also a steering box stabilizer==Good luck
EdmontonCanada
Jul 20, 2010 03:57 PM
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
BigBlue
19
Feb 27, 2007 07:32 PM
kwillis-a
Jan 25, 2007 09:10 PM
