Steering box dribbling..*SIGH*!
Old Aug 11, 2008 | 03:20 PM
dbossdiesel's Avatar
Angry Steering box dribbling..*SIGH*!
Ok, my steering box is leaking at the top through the steering shaft end. My question is, Does ANYONE make a re- sealing kit for the box? I can't afford a new box at the moment. Just seems to me that there should be one hopefuly someone here knows! Thanks for your time!
Old Aug 11, 2008 | 03:35 PM
vzdude's Avatar
DTR's 'Go to Guy'
Take the cap off the PS pump and clean out the vent. My box leaked for somewhere around 20k miles before I did that, and it has been great ever since! Do a search on here and look for the thread. It remarks about making a hole in the rubber in between the 2 pieces of the cap, but I just used about a half a can of brake clean on mine, and it has been awesome, with absolutely zero leaks for about 20K now.
Old Aug 11, 2008 | 03:44 PM
Thank you very much! I totally forgot about that lil' tid-bit! I feel a little dumb for forgetting that! I'll try it and see what it does! Thanks again!!!!!
Old Aug 12, 2008 | 05:15 PM
Well, I cleaned it now lets see what it does! When I took it off it actually poped up with some force! Is there a aftermarket one? Hummmm!
Old Aug 12, 2008 | 06:32 PM
vzdude's Avatar
DTR's 'Go to Guy'
That was what clued me into that being my actual problem! Turn the cap a little and POP! ........good luck!......fingers crossed.
Old Aug 13, 2008 | 03:51 PM
I sprayed the cap down a little with brake cleaner and it seems to be helping a little! It still drips but not as much as it did! I've the holes for venting under the O-ring but, where does it vent out? Not a very good desogn if ya ask me!
Old Aug 13, 2008 | 06:24 PM
vzdude's Avatar
DTR's 'Go to Guy'
If you look at the actual dipstick part of the cap, there is a hole on either side of it. Those are where I sprayed the heck out of the cap at. I used the little plastic tube, to really get it in there too. CAUTION! Use some safety glasses! I got a little in my eyes ( YES I KNOW BETTER! ) and that took a little to get over! LOL
Old Aug 13, 2008 | 06:35 PM
I've got hit in the eye before to! Yes this is me----> Any way I will when I get some more brake cleaner. I had a old can and it was just about empty I'm going to figure out a better way to vent that cap! Hummmm? I'll fab something up and let you know! Thanks!
Old Aug 13, 2008 | 06:49 PM
vzdude's Avatar
DTR's 'Go to Guy'
I pretty much decided that if mine ever does it again, I am going to drill a hole in the top, put a tube in it, and run a hose up to the firewall with a fuel filter on the end of it! It works for differentials and treansfer cases, why not power steering?!?!?!!
Someone on here also has a post about taking the cap apart. Can't say how, but the made the hole bigger in the plasic while it was apart.
Old Aug 13, 2008 | 07:02 PM
Thats what I was thinking! Well, lets see if I can break it! LMAO!!!!
Bark
Apr 3, 2008 02:50 PM
Diesel-Dan
Apr 28, 2004 11:33 AM
Diesel-Dan
Nov 21, 2003 09:16 PM
westcoaster
Feb 1, 2003 01:01 AM
