steaming from under hood !!!
Old Feb 10, 2007 | 11:13 AM
expressfish's Avatar
got home last night and got out of my truck to find it dripping coolant all over the driveway...........expecting the worse I eventually found the upper hose leaking near the neck on the block. Apparently the hose swelled due to age and was rubbing against the pulley underneath it. $20 bucks and an hour later I was good to go, guess it was about time after 102 thousand miles. By the way how easy is it to swap out the water pump if it should ever come to that ?
Old Feb 10, 2007 | 12:32 PM
XLR8R's Avatar
Sounds like that hose was too close to the pulley to begin with!
Old Feb 10, 2007 | 03:10 PM
Thats what I was thinking, but why would it be ? theres no adjustment obviously
Old Feb 10, 2007 | 06:34 PM
timcasbolt's Avatar
Getting the water pump out isn't too bad. I've done it on a 1st gen and it was pretty easy. On a third gen it looks like you'll need to get the shroud out of your way to get your hands in there. Might want to change the tensioner at the same time, just because you're already in there.
DIESELWRKS
14
Feb 21, 2015 05:25 PM
Grand Geek
79
Apr 27, 2012 01:14 AM
Roperteacher
May 10, 2011 01:31 AM
Eddy Reyes
18
Jun 28, 2007 12:06 PM
Dodgezilla
Feb 13, 2004 03:40 PM
