starting problems
Old Oct 26, 2008 | 02:08 PM
ridinhigh's Avatar
starting problems
when I turn the key on everything lights up on the dash but when I go to start it won't do anything. If I turn the key off and then right back on it will start up sometimes..other times I gotta do it about 3 times before it will turn over..then sometimes i don't have any troubles at all I have turned the key over and it won't start and I let out on the clutch alittle and it will turnover alittle and thats it.
Old Oct 27, 2008 | 08:40 PM
BigIron70's Avatar
Cummins Guru
Could be starter going out or bad connection to starter. How are the battery cables clean and tight?
Old Oct 28, 2008 | 09:38 AM
Adaminak's Avatar
My first thought would be internals of the key cylinder. Another thought is the clutch safety switch...especially if you say you can let out on the clutch a little and it cranks. A key cylinder change on my '99 was a pretty simple swap, and it wasn't terribly expensive, so that would be my first course of action. If it's wiring in the steering column though, be careful, because that's a huge rat's nest if you're not comfortable chasing wires.
Old Oct 29, 2008 | 07:37 AM
dieselfumes57's Avatar
mine did this and it was a faulty start tsb and has to be flashed...its been a year ago though
Old Oct 29, 2008 | 02:27 PM
ridinhigh's Avatar
it started fine this morning..after work I tried about 10 times before it started..I had the clutch all the way down and tried to start it and I slowly let up on the clutch and it fired up.
Old Oct 30, 2008 | 03:01 AM
Adaminak's Avatar
That almost certainly sounds like the clutch safety switch.
CLUTCH PEDAL POSITION SWITCH
1. Disconnect switch 2-wire connector (2) attached to
pedal support bracket (1), under instrument panel
to left of clutch pedal.
2. Check switch continuity with an ohmmeter while
operating clutch pedal.
² Pedal Depressed - Continuity
² Pedal Released - No Continuity
3. If continuity is not present or always present,
replace clutch master cylinder.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
