Squeaking from u-joints or brakes?
Old Oct 12, 2009 | 10:54 AM
dave78's Avatar
I am having a squeaking problem (which I first related to a bad rear u-joint). This u-joint was installed for about 1 month, when I started getting a loud squealing nose at low and high speeds. The question is whether or not it is the u-joint or rear brakes. When I apply even very very light brake pressure, the squealing goes away. This is at slow or fast speeds. Any common brake problems I should look at before tearing the u-joint out again?
Old Oct 12, 2009 | 10:57 AM
Lost Lake's Avatar
Brakes have an indicator tab on them that squeals when they are worn out. Replace the pads and move on.
Old Oct 12, 2009 | 11:06 AM
dave78's Avatar
Not really thinking it is the service brakes, they have been really lightly used for 50K miles. Will check it out though
Old Oct 12, 2009 | 11:35 AM
Lost Lake's Avatar
Service brakes? These rear brakes are used every time you press the brake pedal. I am getting a light squeak now also (60,000 miles) and I am due for new tires soon, so that's when I'll check the brakes out.
I can't hear the squeal, too many years of loud noise
Old Oct 12, 2009 | 08:14 PM
billie's Avatar
Sounds like brake pads but 50K shouldn't normally wear out brakes with a manual (cheap pads, lots of use?). If the pads are good, a bit of silicone between the caliper plunger and pad may help. Most replacements come with a small tube to apply when you buy them, did it get installed?
Old Oct 13, 2009 | 06:28 AM
dave78's Avatar
Still has the original stock pads on it.. and i agree that 50K with a 6-speed shouldn't wear out the brakes. I barely used them the first 40K...all highway miles
Old Oct 13, 2009 | 07:19 AM
FirstCTD's Avatar
My truck had the same sound, ony it was coming from the front end. I did the brakes all the way around and sqeeks went away. It sounded like u joints but they all checked out good while replacing the pads. Like your truck, the sounds went away every time brakes were applied
Old Oct 13, 2009 | 10:11 AM
tslewisz's Avatar
My center and far-rear u-joints have been replaced on the rear driveshaft. I'm at 61000 miles. They were squeaking.
Old Oct 13, 2009 | 02:23 PM
Lost Lake's Avatar
I lost those U-joints at about 40,000 miles. Put in greaseable ones. My big fight is with death wobble now. Dodge makes a poor product. If they lose Cummins, they may as well close their doors.
Old Oct 13, 2009 | 04:59 PM
dave78's Avatar
"I lost those U-joints at about 40,000 miles. Put in greaseable ones. My big fight is with death wobble now. Dodge makes a poor product. If they lose Cummins, they may as well close their doors."
-Enough said..Cummins is the only reason I bought a Dodge. Not a big fan of the truck itself
Old Oct 14, 2009 | 01:27 PM
SOhappy's Avatar
It's rare that anybody on here has death wobble with the stock set-up (no leveling kit, no lift, reasonable tires). Are you one of the rare exceptions, or did you mess with it?
Old Oct 14, 2009 | 03:22 PM
wantedwolf's Avatar
I too have the same squeel coming from the drivers front wheel, at various speeds, and a tap of the brakes makes it go away temporarily the pads are quite new and in great shape(with silicone). the u joints were changed last spring.
I had also changed the rotors at the same time as the pads. However I think that the rotor is wearing unevenly. and that is where my squeel is coming from. Havent checked with a caliper yet thou.
tyssniffen
May 7, 2016 01:16 PM
Rob's Red Ram
Dec 10, 2012 05:33 PM
PCM
13
Aug 22, 2010 10:55 PM
Bruce M
Feb 16, 2010 09:02 PM
Dinner
Jan 13, 2007 03:14 PM
