Speedometer option's
Old Feb 20, 2008 | 07:13 PM
nate4567's Avatar
I did a search and I have not found any real answers on what you do when you install bigger tire (35-12.50-20) . I have read that the truspeed doesnt work on a 05 or newer. And the dealers can only do 05's and older. So what else can I do to recalibrate my speed-o
thanks
nathan
Old Feb 20, 2008 | 07:27 PM
snoyes's Avatar
You can purchase a Bully Dog or Smarty and enjoy the power... and also recalibrate for the tire size. I have not heard that the dealers cannot recalibrate tire size? They should be able to do that for you, but no experience of going to the dealer to do that.
Old Feb 20, 2008 | 07:50 PM
nate4567's Avatar
ok, i just read something that said if you have an 05 or older you could take it to the dealer and they could do it. It never said that it couldnt be done it just didnt think it could be
thanks
nathan
Old Feb 20, 2008 | 07:53 PM
JP-4.5's Avatar
Prior to having my Smarty a friend that has a speed shop adjusted mine using a Snap-On scan tool. I am not exactly sure of the model used. I know he has a fairly high end tool. There is a value in the ABS section they can change a value to compensate for tire size. It worked well when I changed from Factory 17" to the Rickson 19.5" rims/tires. If you know someone with a decent scan tool like used at most repair centers I am sure it can be done. Any dealer can make the change also but I believe most of them want to charge you something for it.
Old Feb 20, 2008 | 07:58 PM
nate4567's Avatar
what bully dog do most of you use. I was looking at a bullydog outlook, will that do what I need it to and give me a little performance also??
thanks
nathan
Old Feb 20, 2008 | 08:12 PM
booman70's Avatar
I think you need a Bulldog Tripledog
Old Feb 20, 2008 | 09:32 PM
nate4567's Avatar
Does the quadzilla do anything with for this problem??
thanks
nathan
Old Feb 20, 2008 | 09:55 PM
nate4567's Avatar
thanks
nathan
Old Feb 20, 2008 | 10:07 PM
nate4567's Avatar
thanks
nathan
Maddog
Jan 29, 2003 10:18 PM
TPilaske
Jan 21, 2003 10:36 PM
99 cummins
Dec 18, 2002 01:33 PM
Hummin Cummins
Dec 2, 2002 05:37 PM
RJMontana
Oct 23, 2002 05:06 PM
