Brighter Headlights Option???
Old Jan 29, 2003 | 07:42 PM
Maddog's Avatar
I need brighter headlights. I have the white lights option that came from Dodge but I still think it is dim. I have also installed the Brite Box but that requires you to have your brights on.
Rather than installing driving lights is there an option to install even brighter headlight bulbs in the factory headlight housing?
Has anyone tried PIAA replacement bulbs? I want whatever is next to not being legal or maybe even over the edge. I drive a lot of dirt roads with critters etc and I need the light.
Is 100 watt the max that I can use? Do I have to worry about melting the headlight plugs. What wattage can I get away with? Can they handle the current that the 80 watt filament demands or 100 watt.
If I replace the bulbs do I need new grounding and a set of relays? I am not too mechanical so I am looking for a plug in solution.
Thanks,
MD
Old Jan 29, 2003 | 08:13 PM
Stamey's Avatar
Re:Brighter Headlights Option???
I've been looking at the different kinds they have out there because I'd like brighter ones also. I have seen them on Ebay and other places. <br>Here's a link I was looking at. I am still confused as to which one is brightest though. <br>http://www.sylvania.com/bin/carApp/c...p;x=33&amp;y=8<br><br>Just make sure you get the right kind for your truck. A lot of them I've seen advertised are for direct systems (no reflector at the back) and the 2002 and earlier Dodges use the reflector system. If you put a non-reflector light in there you won't get much light out of it because it doesn't direct light towards the reflector.<br><br>Chris
Old Jan 29, 2003 | 08:38 PM
Davidp's Avatar
I put a 100 watt set from JCW in a Dodge Caravan and melted the plugs. A lot brighter till that happened. Lights would always go off at the best time. 8) Truck plugs might be beefier.
Maddog's Avatar
Chris,<br><br>Thanks for the link. The Silverstar looks like a good option.<br><br>What do HID systems require for installation? Do we just replace the whole headlight assembly with a new headlight or just the bulb?<br><br>http://www.sylvania.com/xenarc/prodinfo.htm<br><br>
Old Jan 29, 2003 | 08:51 PM
Stamey's Avatar
The HID thing is a different headlight altogether, form what I undrstand. See this site. The price difference is what tells me it's an entire headlight conversion.<br>http://www.brightheadlights-hid.com/hid-9004.htm<br><br>Chris<br>
Old Jan 29, 2003 | 08:56 PM
DF5152's Avatar
check the kennedy diesel site they have a kit they market for the Suburban includes wiring and relays to support the extra current draw by bigger lights maybe this will work on the dodge or can be adapted easily.<br>Dan
Old Jan 29, 2003 | 09:02 PM
Stamey's Avatar
More info:<br>http://www.brightheadlights-hid.com/hid_lights_faq.htm<br><br>Chris
Old Jan 29, 2003 | 09:45 PM
mic646's Avatar
Not too long ago I installed Wagner LazerBlue bulbs at around $25.00 for the pair. They are a little brighter then the stock ones, but I still would like to go brighter without doing a bunch of re-wiring.
Old Jan 29, 2003 | 10:00 PM
Stroke This 24V's Avatar
Sport Lamps and Silver Star bulbs = Lots'O'Light
Old Jan 29, 2003 | 10:18 PM
DarrellB's Avatar
[quote author=Stroke This 24V link=board=7;threadid=10259;start=0#98180 date=1043899225]<br>Sport Lamps and Silver Star bulbs = Lots'O'Light<br>[/quote]<br><br>Your door's open. : <br><br>DB
HaulinBut
Oct 4, 2006 06:35 PM
Bassmastermckee
16
Dec 25, 2005 11:15 PM
My 03 HO
Jun 16, 2003 02:38 PM
SjLingenfelter
Mar 3, 2003 06:25 PM
bdog
Nov 23, 2002 09:36 PM
