Speedometer fix
Old Mar 15, 2012 | 09:57 PM
Shorts's Avatar
Originally Posted by prlsnpsdodge
I guess Smarty 's are just that much better than the dealership if it will change the ECM without having to change a specific gear ratio out... And th's dealer can't it doesn't want to help.
The gear doesn't have to be changed. On our 06s they flash the TIPM. Sadly a lot of service guys at the dealerships are kinda ignorant to truck specifics
What part of Tx you in?
Old Mar 16, 2012 | 06:44 AM
prlsnpsdodge's Avatar
I live east of dallas. But I am working north of dfw right now.
Old Mar 16, 2012 | 08:17 AM
no_6_oh_no's Avatar
The deealer simply doesn't know what to do. These trucks have not had a gear drive in the speedometer since 1996. The speed is derived from the ABS sensor on the rear diff. The ABS module provides the signal to the ECU.
The settings available in the ECU are just a limited set of tire sizes instead of a pinion factor like the earlier trucks. If you don't have a set of tires thta matches the standard it is still off. Smarty actually updates the ABS module with a tire height factor to allow small corrections.
Old Mar 16, 2012 | 09:11 AM
Shorts's Avatar
I concur. The dealer said they got mine closer but not exact because they ran out of settings or something like that.
Op, if you can, do get a programmer that can get the speedo corrected. Its still on my list, just can't spent $400 on one right now.
Old Mar 19, 2012 | 11:37 AM
Lost Lake's Avatar
Take it to the dealer and ask for the old trans gear back when he's done...
You need to find someone with a Smarty.... It's an easy change to make and it stays after the Smarty is removed.
And yes you can make minute adjustments the dealer cannot make.
I adjusted my bro-in-laws and he drove his truck to verify the speedo was on while I left the level 3 program on.... You should have seen his face... WOW!!!
It will instantly transform your truck and you will love it.
Old Mar 19, 2012 | 11:54 AM
Well... I just couldn't handle the speedometer being off any longer... it was tearing me up... So I bought be a Smarty Jr.! It'll be here tomorrow morning.
I mean, thus way when I get pulled over for speeding I'll be able to the the officer exactly how fast I was going and why! !
Old Mar 19, 2012 | 12:01 PM
Shorts's Avatar
Have fun with it. And no, I don't know of any tranny shops off the top of my head
Old Mar 19, 2012 | 04:56 PM
SO now I have to find the correct settings.... I'll be running empty for awhlie after this weekend. Only pulling about 8-10K this weekend....
jimbo486
Aug 4, 2012 04:51 PM
Rickcher
Jul 13, 2009 01:22 PM
Dean Snow
Mar 30, 2008 08:50 PM
Dodgezilla
Dec 3, 2002 12:16 PM
