Sounds Like Sand Inside the Tire
Old Dec 2, 2012 | 11:14 AM
06RAM2500's Avatar
And a highway speeds, I have a light, constant vibration. I replaced the left front hub cause that's where the noise was coming from. I also sprayed the back of the pads with squeal stop then to. I set the front end on stands and rocked the wheel back and forth. I didn't see any play in the axle joints, but that probably doesn't mean they're almost, or are actually gone.
Please help me as I'm not really interested in having to fight the front end changing axle joints.
Old Dec 9, 2012 | 02:43 PM
zx14on2's Avatar
there are "beads" etc that could be in the rim, used for balancing the tire. I doubt that you would hear it while driving tho...
Old Dec 9, 2012 | 02:45 PM
zx14on2's Avatar
pull the tire and roll it on driveway, see if you hear it
Old Dec 9, 2012 | 09:31 PM
1-2-3's Avatar
Just a plain ole guy
Put your spare tire on and see if it goes away. i doubt any noise from something inside a tire is going to be heard going down the road. Is the inner fender liners loose and might possibly move and rub? it's probably something but not sand inside a tire.
Old Dec 10, 2012 | 09:01 PM
Kach's Avatar
I had a similar noise and thought it was the bearings - after replacing the front axle u-joints it was gone. A lot of play and really worn per the shop that did the work. I only really noticed the noise in reverse though, which I thought was kind of wierd.
Old Dec 12, 2012 | 07:57 PM
zx14on2's Avatar
when my front u joints went, they squeeled hard, especially on corners, and make a slight clunk, slow speed, wheel cranked
bemhoff
18
Jul 15, 2012 04:55 PM
Dave88LX
14
Sep 1, 2011 11:36 AM
ctd4stan
Jan 23, 2011 11:44 PM
steveb
17
Jan 24, 2004 10:15 PM
