Some negative thoughts on removing the turbo "silencer" ring...
Old Dec 29, 2004 | 04:22 AM
chrismez's Avatar
I pulled mine because I was gettting a "Chuffing" sound when my rig went into OD under hard acceleration. I belive it was back pressure going through the turbo causing the turbo blades to vibrate. No more Chuffing sound after it was removed.....
Old Dec 29, 2004 | 04:24 AM
Dieseldude4x4's Avatar
Don't worry about it, just grip it and rip it.
Old Dec 29, 2004 | 04:42 AM
Dodgezilla's Avatar
I removed my baffles a long time ago but when you look into the tube you can see that it will still cause a lot of turbulence and must surely affect air flow. Last week I installed my Air Flow Systems rubber elbows and 4" intake tubing and got rid of the stock stuff and man that turbo screams now. We took a little trip last weekend and I could not believe that my wife didn't complain at all..
All I got was a piece of stainless tubing and two 90 degree rubber elbows with clamps. I did have to use a part of the stock accordian shaped rubber tubing to help connect to the BHAF but it was all easy. I'll try to get a pic in my gallery.
Old Dec 31, 2004 | 09:49 PM
bishgeo's Avatar
Are we talking the black rubber intake tube from the air box to the turbo.? I thought it was just a smooth tube.
Old Dec 31, 2004 | 09:53 PM
handymantim's Avatar
Yep, that's the tube.
I can't vouch for what they did the year your truck was built but if the factory put something in there and it's hollow now then the previous owner must have removed it.
Old Dec 31, 2004 | 09:55 PM
bishgeo's Avatar
Dodgezilla,Did you have to remove something to lay your BHAF forward.Mine is an 01 maybe 03 is diffrent.Thank's
Old Dec 31, 2004 | 10:53 PM
gsdog1's Avatar
Completely different critters there. The 01, or 2nd gen truck, didn't have baffles like the 3rd gens do. Also, the 01 will have the filter pointing aft. Has more to do with the location of the batteries than most anything else.
Matt
Old Dec 31, 2004 | 11:10 PM
tankeryanker's Avatar
I've been reading about removing the ring & no more huff of the turbo when quickly letting off the go pedal. I just havn't got around to trying it yet.
Any feed back on that theory?
Old Jan 1, 2005 | 07:33 AM
Hounddog's Avatar
I don't won't all that noise.Left mine stock except for the AFE PRO GUARD 7 set up.Could care if I ever heard the turbo spool up as long as it does.
91.5 beater
Aug 10, 2008 08:06 AM
Hohn2
17
Oct 15, 2006 06:51 AM
Hairy1
Dec 1, 2003 06:49 PM
tanderson2002us
Oct 15, 2003 10:24 PM
Hoss
50
Sep 23, 2003 06:20 PM
