Soft Codes
Old Aug 23, 2006 | 02:28 PM
v12xke's Avatar
Soft Codes
How long does it take (or # of key cycles) for soft codes that are set to disappear? My engine light never came on, but I have 3 codes that have been there for about 2 weeks. Nothing major, but I thought they went away after a while? Thanks.
Old Aug 23, 2006 | 05:57 PM
RamWheelsBy4's Avatar
What are the codes, some codes are set and will not clear even with normal scanners (p0633, etc.). They are stored data codes.
Old Aug 25, 2006 | 12:47 PM
v12xke's Avatar
P2269
P0652
P0069
I reversed one of the connections while installing a Quad Std.
Found my mistake and all is well, but I was hoping the codes would go away on their own.
Old Aug 25, 2006 | 01:13 PM
P2269 Generic Water in Fuel Condition - Might want to drain the fuel filter canister to see if there is water.
P0652 Generic Sensor Reference Voltage B Circuit Low - Don't know right off.
P0069 Generic MAP - Barometric Pressure Correlation - This was probably set while installing Quad.
All should go away after enough start/run sequences as long as what caused the DTC is now corrected.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
JoeDiesel
Dec 24, 2002 01:26 PM
93w250
Dec 8, 2002 08:00 AM
