Smelling Fuel???
Old Feb 18, 2003 | 10:48 AM
BamBam's Avatar
Smelling Fuel???
When I stop and get out to open the ranch gate I can smell Diesel...I have looked but cant find any wet shiney spots...but looks like there are some stains around the #6 fuel line all the way in the back...any one eles have this problem? Also the fuel mileage on the computer is going down...started out at 24 and now its showing 18...keep reseting it but dosent get better?? Any ideas...thanks [undecided]
Old Feb 18, 2003 | 06:16 PM
The Boss Hog's Avatar
Re:Smelling Fuel???
BamBam,<br> The smell could be normal if it is coming from the valve cover vent tube. I'll get it every now and then depending on how the wind blows. How many miles on your truck? Check the air-cleaner. If it is dirty, it will cause the mpg to drop.<br><br>Hope this helps,<br><br>The Boss hog<br>
Old Feb 18, 2003 | 08:19 PM
BRDIESEL's Avatar
Re:Smelling Fuel???
??? If you reset the MPH it will start high and drop to the real MPG over time. Also be advised that the odor could be the crankcase breather. I did hear that someone had a fuel leak at #5 injector line, but had fuel leaking all over the block and trans. If you have no visable fuel I would think that it`s the breather ;D
Old Feb 19, 2003 | 08:34 AM
BamBam's Avatar
Re:Smelling Fuel???
I only have 1000 miles and am getting about 17MPG and that is by hand calculation I dont trust the computer. Boy I sure hope that improves...its a 6 speed so I think it should do better. This is a distinct diesel fuel smell...I think I will take it to the dealer on Sat to see what they say.
Old Feb 19, 2003 | 01:14 PM
BamBam's Avatar
Re:Smelling Fuel???
Thanks for that advise...the wife is beating me up over the fuel mileage. After I made all those statements about the awesome mileage I would be getting if only she would let me trade in the F-350 PS for this...well...it ain't happening yet. And she is still fuming…did I mention she wanted a auto too. :-X :-X :-X :-[ :-[
Old Feb 19, 2003 | 09:58 PM
BRDIESEL's Avatar
Re:Smelling Fuel???
What RPM`s are you running the motor at while driving it.<br>If you drive it like a race truck and spin it much past 2200 RPM it will only get 17 or less. I run about 2000 to 2200<br>on the freeway and shift at 1800 to 2000 and I`m getting 18.4 at 3200 miles. ;D
Old Feb 20, 2003 | 06:58 AM
Hummin Cummins's Avatar
Re:Smelling Fuel???
[quote author=BRDIESEL link=board=20;threadid=11109;start=0#106744 date=1045713480]<br> What RPM`s are you running the motor at while driving it.<br>If you drive it like a race truck and spin it much past 2200 RPM it will only get 17 or less. I run about 2000 to 2200<br>on the freeway and shift at 1800 to 2000 and I`m getting 18.4 at 3200 miles. ;D<br>[/quote]<br><br>I get similar results from the overhead...actual calculations are roughly 0.5 mpg lower than Mr. Kom-Poo-Ter.<br><br>Although I shift at 22-2400 and maintain speed in any gear between 1800-2000rpm (63-67mph).
Old Feb 20, 2003 | 07:46 AM
BamBam's Avatar
Re:Smelling Fuel???
I try to keep it below 2000 RPM but at 70 its running 2200 RPM ...so that cuts into the milage a bit I am sure..I will try to keep it below 2000 and see what happens.
Old Feb 21, 2003 | 05:18 PM
BRDIESEL's Avatar
Re:Smelling Fuel???
??? So what`s the word on your so called fuel leak ???
Old Feb 21, 2003 | 05:44 PM
westcoaster's Avatar
Re:Smelling Fuel???
BamBam,<br>What is it with clearance lights and women ??? My wife hates the clearance lights too, says it looks like we are (would be) hauling produce for Safeway.
Old Feb 24, 2003 | 08:01 AM
BamBam's Avatar
Re:Smelling Fuel???
Took it to the 5***** dealer on Friday they tightened the #6 injector line...but I still smell something. Someone on this site said something about the crank case vent mod. Any ideas on that would be good. Had the dealer also check the rear end and it was OK. Also checked a knock about 1500-1800 RPM..said they all do that...anyone else have that? ???
Old Feb 24, 2003 | 01:16 PM
BamBam's Avatar
Re:Smelling Fuel???
The spousal unit says they look like a tow truck... ??? ???
Old Feb 25, 2003 | 12:59 PM
LonCray's Avatar
Re:Clearance Lights
My wife thinks they're sexy - I've even got her believing that diesel is the smell of victory!
ezdemon72
Dec 28, 2010 07:26 AM
phal
Feb 17, 2009 01:55 PM
anpconnors
Nov 7, 2006 11:38 AM
digbog
Aug 26, 2006 10:22 PM
skargo
15
Apr 28, 2006 02:24 PM
