Slave cyl issue?
Old Nov 8, 2015 | 05:56 PM
Griffsyj's Avatar
Slave cyl issue?
Hey all, I have a 2006 2500 single cab, long bed, 4x4 with 6speed. 74000 on the clock. I'm having a clunk noise that I think could be the slave cyl but I'm not sure. If the truck is out of gear, and you push the clutch in..you can hear a slight clunk as you take your foot off the clutch...but it's much more prominent while moving the truck from a dead stop, or while letting the clutch out after I've grabbed the next gear. When you change gears and let the clutch out, the clunk can be felt and it slightly jars the truck. Also when the clutch is pushed in, and you change gears, you can feel the shifter catch slightly as your shifting into the gear. It doesn't matter what gear the truck is going into.
I have a hard time believing that the clutch is going out at 74000 miles, but does it sound like to you guys that the slave cylinder might be on its way out? Or that the master cylinder isn't pushing enough pressure to the slave?
96turbodiesel
Aug 9, 2007 09:04 AM
GR40RCapri
16
Jan 18, 2007 02:07 PM
Fishbait
Jun 6, 2006 12:34 PM
cummer01
May 27, 2004 04:07 AM
