Simple injector question?
Old Jan 5, 2010 | 02:29 PM
eot's Avatar
eot
Hey guys,
I just bought this 06 w/ 5.9 the dealer said they just had injector work. On my old 01 It had 186000 original injectors ran great! Question is what symptoms do i look for when injectors are going bad. Rouh Idle i read what else? And do you have to replace all of them at once. I did purchase an warranty program thru the dealer that actually covers injectors. So I want to make sure when it needs them. From the sounds of it it will be cause of the 06 model. Thanks
Old Jan 5, 2010 | 03:20 PM
rich's Avatar
rough idle, white smoke, diesel in the oil are some of the symptons. if you change your fuel filter often or put a lower micron one on you will have less of a problem
Old Jan 5, 2010 | 04:35 PM
eot's Avatar
eot
Thanks what is the best micron fuel filter to use and brand I use to use a napa brand in my 01.
Old Jan 5, 2010 | 04:58 PM
6speedcowboy's Avatar
i would run the 3 micron fleetguard filter from cummins. staying away from bio diesel will also help to increase injector life
Old Jan 6, 2010 | 08:10 AM
CRToney's Avatar
GDP makes a 2 micron filter kit.
jumpinj
17
Dec 15, 2005 10:38 PM
HorseHauler
Nov 7, 2005 09:32 PM
ExactOh
May 4, 2005 10:04 PM
dieselcrazy
Jan 5, 2004 03:39 PM
