Silencer Ring
Old Mar 3, 2004 | 11:02 PM
HighTen's Avatar
Question Silencer Ring
What exactly is the "silencer ring." From what I've read, it seems to be something next to the turbo that makes it quieter. Is this right? Is it easy to take out? I sure want to hear the turbo on my new truck when it comes!
Old Mar 3, 2004 | 11:42 PM
MoreSmoke's Avatar
Do a search you will get all the info you need. It is easy to take out. Remove the intake tube from the turbo housing. The Silencer ring is a nose cone shaped disc inside, it is held in by a snap ring. On the 3rd Gen's it can be kind of a P.I.T.A to take out do to the location of the turbo. It is easier on the second Gen's. It took me about 30 minutes to pull the one on my girls 03. You will definitly get a nice turbo whistle once it is removed.
Old Mar 4, 2004 | 01:38 AM
dodgedude361's Avatar
agreed, it took me about 20 mins to get mine out...half the time was looking for i TINY screwdriver, to get under the darn thing ...now with my pro guard7 , i CAN REALLY hear her sing
Old Mar 4, 2004 | 04:46 AM
Dodgezilla's Avatar
I went a couple steps further and removed the baffles from the big tube before the turbo. Added in a AFE filter and WOW!
Genos Garage sells a replacement for the tube for anyone who doesn't want to alter their stock unit...
Sounds SCHWEEEEET!!!!!
Old Mar 4, 2004 | 05:37 AM
RamDan03's Avatar
I also replaced the baffled intake tube with an AIRAID tube. The silencer ring took less than 10 minutes to remove. Having two small flatheat screwdrivers makes the job pretty painless. You will like the resulting sound!
Old Mar 4, 2004 | 07:58 AM
I forgot to mention that i also removed the baffle tube. A member here made me one( thanx Mark) That is key, more than the ring,
Old Mar 4, 2004 | 11:05 AM
NDanecker's Avatar
Is the ring also installed on the 600 motors and can it be removed?
Old Mar 4, 2004 | 11:18 AM
as far as i know, the ring is on ALL CTD`s. do a search on "silencer ring removal". when i was doing mine last summer, a member ran a thread on its removal. It was complete with pictures. Its real easy
Old Mar 4, 2004 | 11:32 AM
bigblock2stroke's Avatar
By baffle tube, are you refering to the foot long straight tube between the airfilter and the turbocharger compressor inlet? If so, then yes, the 600 has one. Its supposed to help with turbo noise. I would be interested in seeing what you replaced it with. Got any pix?
Old Mar 4, 2004 | 02:42 PM
HighTen's Avatar
Thanks for the comments!
I'll definitely search the forum and find more info and pictures about the silencer ring.
Old Mar 4, 2004 | 10:45 PM
Teddroe's Avatar
Hey Big Block
You seen to know a lot about these new 600's. I've been hearing a lot of different opinions on this subject. Do you know for sure if the 600 has a cat converter or is it a resonator? if its not a california model......
Old Mar 5, 2004 | 11:48 AM
Jonny Two Guns's Avatar
I was going to start a new thread but I'll add to this one because it may have to do with what I'm going to mention. I'm not sure what or where this noise is coming from but I'm pretty sure it's from the turbo.
I have noticed a "noise" usually when the truck has been first started or what I'm going to call "cold". It sounds more like a large fan rather than the turbo but as the truck gets warmer or I push up the RPM's this noise turns into the turbo whistle I'm use to. I was just wondering after reading this thread. Could this silencer ring make or cause this fan sound I'm hearing at lower RPM's or when the truck is cold?
Old Mar 5, 2004 | 11:54 AM
NDanecker's Avatar
My TDI is a variable vane turbo and makes different weird noises as it warms up (straight pipe from turbo back so the turbo wine is really pronounced). Do the new 04.5's use a Variable vane turbo or is it still using a waste-gate type???? IF variable, you'll hear the different sounds as the vanes adjust controlling turbo RPM.
Just my opinion here so correct me if I'm wrong.
Old Mar 6, 2004 | 08:24 AM
i-bleed-disel's Avatar
teddroe its a cat i removed mine 2 days agao im uncorked now but will be instaling a x brake and 5 " xaust dumping in front of rear dual wheels
Old Mar 6, 2004 | 06:57 PM
HighTen's Avatar
i-bleed-disel,
Have you noticed a big difference after taking off the cat? Does it sound different or have more power or get better fuel economy? That is very interesting because I plan to do the same thing with mine when it arrives!
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
