Shutter while coming to a stop...
Old Jun 16, 2009 | 03:51 AM
Hamilton713's Avatar
My truck has 58,000 miles on it, with the last 6,000 being mine. It has developed a shutter while slowing down and comes on at about 20 mph down to 10 mph then seems to get less pronounced. When it first did it, it felt like I was driving on rumble strips. Well I wasn't so I thought I had a flat tire but that wasn't the case either. When it started this shutter, it was doing it while driving forward as well as slowing down.
I thought it might be the clutch but it does it with or without the clutch pedal depressed. It also does it while not pushing on the break pedal.
Another kicker, is that after driving it that way for the weekend (no other option) it went away for a couple weeks but now its back but not as bad.
I thought it was my front-end going out because I did need new upper ball joints and inner tie rods so I took it in and had them replaced. However, it didn't fix the shuttering issue, which now only does it while slowing or stopping.
I think my steering box is going out because the mechanic said he adjusted it but it was still loose. Could this possibly be the culprit?
Also, what are you guys replacing the stock steering gear box with?
Thanks
Old Jun 19, 2009 | 07:08 PM
KSwanner's Avatar
Check all the u-joints on your drive shaft. That could be your trouble, I have had two go out in 108,xxx.
Old Jun 19, 2009 | 07:21 PM
1985cucv's Avatar
yeah i would say u joints. myself check for play they are a pita to change or at least mine were.
Old Jun 19, 2009 | 07:30 PM
bggrnchvy's Avatar
Parents 05 had the same type of problem at 70k miles. Took me a while to figure it out as the u-joints didn't have slop and the seals 'looked good'.
Finally figured it out as I was under the truck at dusk with a flashlight and the light hit a glimmer. That glimmer was a little bit of exposed u-joint trunion from 1/3 of the sealing lip on one of the caps being gone. Tore it apart and the cap was dry and the bearings were seizing to the trunion at low speed or at really high speed (60mph+).
I'd definitely suspect u-joints and go over them with a fine toothed comb.
drafalske
Apr 14, 2011 07:08 AM
Badd Dogg Guy19
Jan 28, 2011 11:00 AM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
Hounddog
Nov 1, 2006 05:26 AM
